when to switch to a pro gear ?
I think I already know the answer to this but , when do people switch to a pro gear ? if the street gear fails will it just strip teeth off ring gear or more damage ?
3950lbs 1100+hp 10 in tire 3.50 gear trans brake
thanks, wayne
thanks, wayne
wayney- Posts : 187
Re: when to switch to a pro gear ?
IMO at that weight & that power range with a T-brake using a Pro Gear is definitely a better idea than a street gear.
DILLIGASDAVE- Posts : 2262
thanks, that is what I am hearing. does the 28 spline pinion fail or do they usually strip the teeth off the gear? 8.8 rears are only available with 28 spline pinion gears
thanks, wayne
thanks, wayne
wayney- Posts : 187
wayney wrote:thanks, that is what I am hearing. does the 28 spline pinion fail or do they usually strip the teeth off the gear? 8.8 rears are only available with 28 spline pinion gears
thanks, wayne
Don't know about the 8.8 but I have seen the 12 bolt stuff knock the teeth off street gears.
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
» 460 rotor gear connecting gear bad
