valve cover gaskets
o henry
valve cover gaskets Empty valve cover gaskets
Post  o henry June 12th 2019, 9:59 am
what valve cover gaskets you guys using when taking off covers multiple times when adjusting valves that does not not squeeze out (rubber) or crack (cork). i only snug them up then snug up more when they leak ?.
o henry
valve cover gaskets Empty Re: valve cover gaskets
Post  rmcomprandy June 12th 2019, 10:39 am
o henry wrote:what valve cover gaskets you guys using   when taking off covers multiple times when adjusting valves that does not not squeeze out (rubber) or crack (cork).  i only snug them up then snug up more when they leak ?.
I use the O.E.M. silicone coated steel gaskets from a later model F.I. engine. They require FLAT valve cover rails and covers.
Post  Lem Evans June 12th 2019, 10:59 am
The Cometic are as tough as I have seen.
Post  cool40 June 12th 2019, 8:46 pm
Cometic are the best I’ve ever used! Probably been off 50-75 times and still no problems. They’re a little hard and don’t like swapping around or they’ll leak till seated back in. 😎
Post  Mark Miller June 12th 2019, 10:45 pm
I've had pretty good luck with the Cork Rubber Fel-Pro's FWIW!!
Post  kjett June 13th 2019, 8:58 am
I've had good luck with the blue silicone, steel cored ones from Moroso. Take them off often to check lash and no leaks
kjett
kjett
Post  away June 13th 2019, 10:57 am
https://www.jegs.com/i/Moroso/710/93065/10002/-1
Yelp Moroso is the ones I use.
away
away
