first big block build
rmk57
jreber
any hints on my first big block build
jreber- Posts : 4
Re: first big block build
Have a look at this and see where you want to go.......https://www.460ford.com/forum/40-engine-build-archive/119213-460-horsepower-chart-revised-1-24-09-a.html
copy and paste into your browser.
rmk57- Posts : 176
Need more info
Tell us what your plans are .Is this for a street car drag car pickup truck . Having a good machinist familiar with fords goes a long way.This is a good forum you will receive good ideas but a bit more information will help us to help you .Doug
manofmerc- BBF CONTRIBUTOR
thanks for the help, i plan on this being a daily driver, but i want it to be a little better than stock. i wanna spin the tires and be able to drive this everyday
goin into 72 tbird
goin into 72 tbird
jreber- Posts : 4
block has been machined already, 30 over on block and 10 under on crank. machinist is very knowledgable and been doing this for 20 years
jreber- Posts : 4
Sounds like you've decided on a 466" engine so you'll want to build for torque based on on the build chart already mentioned since your going to be putting it in a heavy car like the T-bird.
427John- Posts : 86
well i didnt decide on a 466, the block needed that much work to get it right, so this is what i have to work with. i do have a specific question, do i need to watch piston ring gap on this particular engine build
thanks in advance
thanks in advance
jreber- Posts : 4
jreber wrote:well i didnt decide on a 466, the block needed that much work to get it right, so this is what i have to work with. i do have a specific question, do i need to watch piston ring gap on this particular engine build
thanks in advance
As long as it is large enough for the pistons being used.
Most often ... recommended top ring end gaps are a minimum needed to prevent "end butting".
» hello i just brought 2 BBF engines. new to them. which block to build?
» Aluminum M6010A96 block build
» stock block 565 build
» new build block info
» Stang TV Big block ford Build...
