Aluminum M6010A96 block build
First 598 aluminum block build. Ford M6010A96 block. 4.600 bore x 4.500 stroke. Need help with the oil galley plug location for the lifter galley. Do I need to plug the right side in the front or rear of the lifter galley? Looks like you would want 1 side fed from rear and other side fed from front. Is this correct?? Block was originally used dry sump, I will be turning it into wet sump after drilling the oil feed from the oil pump mount and using a Kaase oil pump. Then I need to look at the oil drain back and if I need to change anything.
No1Fordnut- Posts : 1
» If you swap from iron block to aluminum block,,,
» C&C aluminum block
» Aluminum vs Iron Block ?
» Looking for Aluminum block and 5.25" crank
» anyone looking for a aluminum block
