failed flexplate
+6
Mark O'Neal
Wayne Pearce
aquartlow
Gregaust
jpierce55
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: failed flexplate
jpierce55 wrote:I finally pulled the fp. The tightness and noise, it was rubbing the block/trans plate. Looks like it is warped, 1/4 seems to not sit flat. I never considered checking flatness. Live and learn. No more Scat fp's for me!
Make sure the difference is something other than the name.
Mark O'Neal- Posts : 286
Building a 500 CI pulling motor, looking to make close to 1100 HP. I’m looking for suggestion for a crank shaft was looking at Bryant ,Crower etc.
Suggestions in who to use.
Sstruckpuller- Posts : 1
Crower, with the pendulum undercut counter weights....allows you to run lighter weight pistons / rods.Sstruckpuller wrote:Building a 500 CI pulling motor, looking to make close to 1100 HP. I’m looking for suggestion for a crank shaft was looking at Bryant ,Crower etc.
BBFTorino- Posts : 998
Wouldn't pulling get an advantage from the inertial weight of a heavier assembly?
For anyone following on fb, you probably know...aftervchasing some fuel system issues I unfortunately had the oem unit fail as well. The engine had been cranking easy, with no tight spot, but it kicked back. I may have to go CSR with replaceable ring.
jpierce55- Posts : 111
Mark O'Neal wrote:jpierce55 wrote:I finally pulled the fp. The tightness and noise, it was rubbing the block/trans plate. Looks like it is warped, 1/4 seems to not sit flat. I never considered checking flatness. Live and learn. No more Scat fp's for me!
Agree with you there. Hughes look about the same as Scat. Maybe they are better, but....
I had a customer that finally changed to ATI for a flexplate. Quite pricey, but zero problems since. I would strongly recommend.
pmrphil- Posts : 170
Hays
Those ATI flex plates are nice and expensive .Hays has a heavy duty sfi flex plate available for about $110. I just bought one really thick and well made . I wish they made one for the FE though .Doug
manofmerc- BBF CONTRIBUTOR
Page 2 of 2 • 1, 2
Page 2 of 2
