CJ port valley pan intake gasket
Is there a valley pan gasket available for 429SCJ? My original iron intake is missing the steel baffle from the bottom of the intake, and it's my intention to use the heat crossover. I've read that oil might fry on the bare intake bottom without the baffle or valley pan.
Calypso- Posts : 71
Re: CJ port valley pan intake gasket
Calypso wrote:Is there a valley pan gasket available for 429SCJ? My original iron intake is missing the steel baffle from the bottom of the intake, and it's my intention to use the heat crossover. I've read that oil might fry on the bare intake bottom without the baffle or valley pan.
Not that I know of ... only a regular production size port.
Thank you. Suppose I need to fabricate a makeshift shield.
Calypso- Posts : 71
There is a truck intake gasket set which has a separate valley pan. I don't know the number but I see them on e-bay a lot. Hope this helps.
jeffgfg- Posts : 338
jeffgfg wrote:There is a truck intake gasket set which has a separate valley pan. I don't know the number but I see them on e-bay a lot. Hope this helps.
He's looking for the CJ size port Valley Pan!!
Mark Miller- Posts : 1959
I understand but the valley pan is separate from the intake gaskets. The valley pan rest on the china walls. I figured you could use just the valley pan and use CJ intake gaskets. Maybe???
jeffgfg wrote:I understand but the valley pan is separate from the intake gaskets. The valley pan rest on the china walls. I figured you could use just the valley pan and use CJ intake gaskets. Maybe???
Problem is the Valley Pan also wraps around the ports not just the china wall and the Valley Pan ports wouldn't match the CJ Gaskets!!
Mark Miller wrote:jeffgfg wrote:I understand but the valley pan is separate from the intake gaskets. The valley pan rest on the china walls. I figured you could use just the valley pan and use CJ intake gaskets. Maybe???
Cut the flange gasket part of the pan away is what I think he meant.
rmcomprandy wrote:Mark Miller wrote:jeffgfg wrote:I understand but the valley pan is separate from the intake gaskets. The valley pan rest on the china walls. I figured you could use just the valley pan and use CJ intake gaskets. Maybe???
I don't remember the brand, but I had a set that was separate, with a piece of steel that just covered the valley and didn't go up onto the heads.
cletus66- Posts : 865
Here is one as I described:
https://www.ebay.com/itm/Mahle-MS15937-Intake-Manifold-Set/264494730834?fits=Year%3A1985%7CModel%3AF-350%7CSubmodel%3AXL%7CEngine+-+Liter_Display%3A7.5L%7CMake%3AFord%7CTrim%3AXL+Crew+Cab+Pickup+4-Door%7CEngine%3A7.5L+460Cu.+In.+V8+GAS+OHV+Naturally+Aspirated&epid=175045935&hash=item3d951d4e52mteYOpIr4IAthXH4R6XTOFg
That's the one I was thinking about..... Thanks !!!
jeffgfg wrote:That's the one I was thinking about..... Thanks !!!
No problem. I had one of those pans hanging on the wall and knew exactly what you were talking about.
That should work, thank you!
Calypso- Posts : 71
» intake gasket fit
» Square port intake vs oval port
» felpro intake gasket # for use with vicktor or tfs intake ?
» Intake gaskets
» Looking for someone who can port my intake
» Intake gaskets
