gear ratios.
gear ratios.
I am using hales formula for optimum gear ratio calculation in a 1/4 mile. Anybody have an easy way to figure an 1/8 mile rear gear? based on HP, weight, rpm, tire size?
I don't have scales so I'm going off what the previous owner of the car says it weighs and adding some for the big block. The 1/4 mile formula says I need 4.32
stanger68- Posts : 500
» gear ratios
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
