Oil pan, pump combo- 598
2 wicked
Oil pan, pump combo- 598 Empty Oil pan, pump combo- 598
Post  2 wicked October 13th 2020, 3:24 pm
Hey all. Been looking at oil pans and pumps, looking for a box style pan,full baffled and built in windage tray, wet sump. Moroso, canton, kevco, etc. We have a eliminator ultra block, 4.5 stroke with aluminum rods. What pan pump combo do you all like and why? Thanks cory
2 wicked
Oil pan, pump combo- 598 Empty Re: Oil pan, pump combo- 598
Post  Dave De October 14th 2020, 5:44 am
Talk to Lem.
He's got a fab'd pan that is a good buy for the money.
RACERX likes this post
Post  stanger68 October 14th 2020, 9:16 am
I second the pan from lem. I recently bought one. Haven't used it yet but it is a lot better than my old off the shelf pan for sure. Very fair pricing.
Post  2 wicked October 14th 2020, 6:26 pm
Thanks for the info will give lem a call. Wanted to go dry sump on this build, just don't have the extra cabbage!!!! We have a hi flow Dynamics pump in our current 557. Going to call Paul and see what pan he recommends as well. Both those guys are great to deal with!!!! Thank cory
2 wicked
Post  away October 17th 2020, 9:26 pm
I run a 632 with Moroso 20616 pan and Kaase pump with a small plate welded to the pickup tube to cover the hole for the pickup .....Kaase told me to do this. It turns that pan into a great pan with the bigger CI stuff so I am told! Good luck so far 5.0's and hoping for 4's naturally aspirated.
away
away
Post  2 wicked October 18th 2020, 7:07 pm
Away, I looked at that pan. But it requires a tilton starter and 184 t flywheel. At least that what info I found at summit. Would prefer to stay with standard flywheel size and my power master ultra torgue starter. Think I will probably go canton or get a quote from lem on a pan pickup combo. Thanks cory
2 wicked
Post  Dave De October 18th 2020, 10:16 pm
2 wicked wrote:Away, I looked at that pan. But it requires a tilton starter and 184 t flywheel. At least that what info I found at summit. Would prefer to stay with standard flywheel size and my power master ultra torgue starter. Think I will probably go canton or get a quote from lem on a pan pickup combo. Thanks cory
I'm using the Moroso 20616 pan now with the standard flexplate and a regular PMGR starter. The same setup that I used on Lems aluminum pan before a wheel stand took it out. Its true that the pans are wider than a flanged pan.
Post  Lem Evans October 19th 2020, 11:23 am
I have a pan in stock.
Post  Lem Evans October 19th 2020, 11:26 am
https://www.429-460.com/t24984-custom-pans-for-sale
Post  2 wicked October 19th 2020, 5:39 pm
Thanks lem, will be getting in touch with you about a pan and pickup assembly. Thanks again cory
2 wicked
Post  2 wicked January 13th 2021, 2:34 pm
Thanks to Lem, we got one of his custom pan and pickup assembly. Just like the one in the B F Evans Sticky. In the for sale section. Craftsmanship is top notch. Now for the pump, toss up between kaase or hfd. Had excellent results from Paul's stage 2 we have now. Cory
2 wicked
Post  dfree383 January 13th 2021, 2:46 pm
Kaase’s pump is a much better design
