Parts selection for blown application (Budget - Mild Boost)
+8
cstmwgn
Uglytruck
quarterflash
12 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Blown mild build.
I've been running blown 385 series engines over 15 years now, first did a 8-71 blown 460, and now a 8-71 blown 521. What is the CC of your heads ? The compression will be determined by you head combustion chamber and your piston choice. In a mild build stock stroke the factory D3 heads and forged replacement dish top pistons give you around 8 to 1 which is perfect for gasoline. With a 6-71 you will need to spin the blower a little faster drive wise to make decent boost. With your stroked crank I'd still look for a forged dish top piston. You might contact Paul Kane / High Flow Dynamics on the forum as he has lots of piston sets he might have something you can use at a decent price, great guy to deal with. Buy some good head gaskets what ever you do, Cometic or something like Ford Racing with fire rings. Your 750 carbs set up for boost will run awesome that's what I used on both my engines. Many camshaft companies make blower grind cams, I went through Hampton Blowers who had Crower custom grind me a cam it's been fantastic and easy on the valvetrain. Get your distributor set up for a blower, too much timing is a bad thing.
blown473- Posts : 376
Re: Parts selection for blown application (Budget - Mild Boost)
blown473 wrote:I've been running blown 385 series engines over 15 years now, first did a 8-71 blown 460, and now a 8-71 blown 521. What is the CC of your heads ? The compression will be determined by you head combustion chamber and your piston choice. In a mild build stock stroke the factory D3 heads and forged replacement dish top pistons give you around 8 to 1 which is perfect for gasoline. With a 6-71 you will need to spin the blower a little faster drive wise to make decent boost. With your stroked crank I'd still look for a forged dish top piston. You might contact Paul Kane / High Flow Dynamics on the forum as he has lots of piston sets he might have something you can use at a decent price, great guy to deal with. Buy some good head gaskets what ever you do, Cometic or something like Ford Racing with fire rings. Your 750 carbs set up for boost will run awesome that's what I used on both my engines. Many camshaft companies make blower grind cams, I went through Hampton Blowers who had Crower custom grind me a cam it's been fantastic and easy on the valvetrain. Get your distributor set up for a blower, too much timing is a bad thing.
The M-6049-SCJ Heads have a 72cc combustion chamber. Based on your input and several others I starting to see two clear paths.
Mild blown gas (as follows):
Block: D9TE-AB (std)
Crank: Ford stock Crank 3.85 Stroke
Rods: CRS6605F990 Eagle,429/460 Big Block Ford, 4340 Forged H-Beam 6.605" Rod, Pin End Bore 0.990 in.
Heads: M-6049-SCJ (72cc chamber) Exhaust Valve 1.76 in , Intake Valve 2.2 in
Pistons: TBD (0.990 in Pin seems to create a problem)
Cam: TBD
Manifold: BM-5056 429-460 FORD UNPOLISHED BDS INTAKE SATIN
Blower: 6-71
Injection: Enderle Bird Catcher
Mild (if that's possible) Blown Methanol:
Block: D9TE-AB (two available - .060 over or std) Wanted D0VE block but tired of looking locally
Crank: Eagle CRS446041402200 4340 Forged Crank 4.140 Stroke
Rods: GRP Alumimum 6.7
Heads: M-6049-SCJ
Pistons: TBD (Diamond > Budget) Outstanding website though
Cam: TBD
Blower: 6-71 (I know its small but "Budget - Mild Boost")
Injection: Enderle Bird Catcher Fuel will be high octane Gas
If Paul's on here I'd be happy to have him PM me about pistons he may have available.
Steve
It appears you're attempting to build a blown 385 Series on a budget; those two words ("budget" & "blown") don't typically belong together. Some of the listed parts I might use on a budget blower engine, and some I would not use on a higher powered blown engine and/or are not well suited for a blown stroker engine. So if budget is the focus here--and you're stuck with the 6-71--I suggest the following:quarterflash wrote:I’m going cross eyed searching the internet trying to fill in the blanks “TBD” on this project. The parts in bold have already been acquired. Pistons are my biggest frustration. Haven’t even considered cam choice yet and rods seem easy after pistons are selected. Your input would be greatly appreciated!
Heads: M-6049-SCJ
Cam: TBD
This engine will be an upgraded for 1978 Cole Hydro "Quarter Flash".
Thanks in advance for your help.
Steve
Budget Blown 460 with 6-71:
Pistons: Forged 460 flat tops with 0.990 in Pin (yes, they are available)
0.093" copper head gaskets
(Final compression ratio ~10.5:1)
Cam: TBD
Blower: 6-71, 15-20% overdriven
Methanol for fuel
You must cut/machine the length of a spacer sleeve down so as to fit past the timing cover seal and barely protrude forward of the seal, then flip the blower hub around so that the belt cog is up against the timing cover.
(There is more to the details of the build)
If budget is not an issue, then lose the 6-71 for something larger, 4-bolt the D9TE block, stroke the engine, etc.
Please call directly for any further details.
Page 2 of 2 • 1, 2
» Pistons, rods, cam for low RPM mild boost
» Boost vs Cubes vs The Budget
» Budget parts for my 460 build
» Budget Build with bolt on parts
» Budget Street/Strip Stroker Build Advice w/ Existing Parts plus???
Page 2 of 2
