Budget parts for my 460 build
barbatostan
OldRed70
69bluehotrod
bigblockf100
Im currently looking for parts for a 78 460:
Roller rockers
good cam shaft for a weekend wheeler with a lopy idle and decent vacuum for the brakes (possible roller)
flat top pistons
fenderwell exit headers
master engine kit
hv oil pump
gear drive timing set or new double roller
Hopefully these parts are out there ive been searching for new stuff and its pretty damn pricy.
Roller rockers
flat top pistons
master engine kit
hv oil pump
bigblockf100- Posts : 13
Re: Budget parts for my 460 build
Let me check at the shop, but I think I still have this
it a Pete jackson "noisy"
and I pretty sure i have a new HV oil pump
would take 150.00 = the ride for both, would that help you out?
Yeah thats awesome. At least i can start getting stuff together. With that timing set do know if ill be able to degree my cam once i put it in or will i even have too. Also do you need to modify the timing cover for the pete jackson gear drives i know on a couple other ones they have to be but not sure on the 460s
I have got a set of used Comp Roller Rockers 1.73 Cast Aluminum
Eagle H-Beam Rods 6.605
SRP flat top Pistons -3.00 Forged Aluminum 4.390 Bore
Comp Double Roller timing Set
Also got Comp Hyd. Flat Tappet Cam And Lifters 292H .560 Lift .292 Duration
Everything has Less than 8000 miles on them
OldRed70- Posts : 155
what were you thinking on prices for that stuff? How big is that cam too? my truck is still gonna need low end. Im not real Cam savy. just got an idea of the the power and sound im looking for. And any pictures?
bigblockf100 wrote:Yeah thats awesome. At least i can start getting stuff together. With that timing set do know if ill be able to degree my cam once i put it in or will i even have too. Also do you need to modify the timing cover for the pete jackson gear drives i know on a couple other ones they have to be but not sure on the 460s
Sorry I did'nt get to the shop last night, I forgot my yougest son was test for his blue belt, I will get there tonight,.
You will be able to degree your cam as it does have + / - * settings on the gear set, we did not have to modify stock timimg cover when we ran this.
Have a line on a guy that i bought my engine kit through. Totally legit, bought my kit with all gaskets rings and bearings. Company says there gaskets are made by felpro and viictor. only cost me $125. if you like ill get the number out of the shop monday.
barbatostan- Posts : 19
I have a new in the box roller cam. Its 226/226@50 595/595 lift. 110 c/l I am just going bigger. $100 plus the ride. My number is 815 325 1382. Thanks John
radir 68- Posts : 6
sorry bad thought never mind
bosshoss- BBF CONTRIBUTOR
I also have a set of new in the box Weisco pistons. They are 30 over for stock head and rod. Just going bigger. Nedd to get the $400 I got in them. Plus shipping. 8153251382
radir 68- Posts : 6
have an entire 460 for sale on 460ford forum asking 1000 http://www.460ford.com/forum/showthread.php?t=161655
gibs0n06- Posts : 2
i will have a set of speed pro flat top pistons maybe 20 passes.on them standaed bore 4.36 i take $100 + shipping or I leave the truck rods on them for $150 + shipping.pm.me if you are interrested
» Budget Build with bolt on parts
» Budget Street/Strip Stroker Build Advice w/ Existing Parts plus???
» need help budget build 460
» low budget 460 build up
» Which cam for this budget 351w build ?
