low budget 460 build up
I'm new to Bigblocks I need help! I'm Want to build a low budget high horsepower 460 how could I accomplish this? I want the horsepower range to be between 500 or 600 hp thanks.
Lugnut- Posts : 1
Re: low budget 460 build up
give this a read first it will really help you out
http://460ford.com/viewtopic.php?t=23787
i
i would use the probe i-beams and flat top pistons, victor dominator intake, comp 294-b solid flat tappet cam, 1050 dominator carb, and for $25-go to scotty's site and port your self a set of c8-c9, or doves and you will be there at 500. if you can get the 340 cfm on intake and 190 on exhaust, you will be at the 550 mark. i made just under 500 with this combo with 310cfm home port heads and stealh intake , 850 carb in a 69 mustang with shitty restrictive crities headers imho "jay"Lugnut wrote:I'm new to Bigblocks I need help! I'm Want to build a low budget high horsepower 460 how c
jm- Posts : 65
Dang thats good Jm and X2 on what he said
Old blue Racin Team- Posts : 1579
i like to add about my build that it had stock truck rods and hyper pistons thats why i suggested the upgrade rods and pistons.it made it in my car for over 5 years
jm- Posts : 65
There is no such thing as low budget and 500+hp. You can cut some corners, but you still need to realize that this is beyond the abilities of the stock rods and cast or hyper pistons. I am not saying you need to spend $10k, but it will be more than $4k. The above advice is very sound, and I would do the H-beams over the I-beams, in case you want to add more to it later. The upgrade is minimal in price.Lugnut wrote:I'm new to Bigblocks I need help! I'm Want to build a low budget high horsepower 460 how could I accomplish this? I want the horsepower range to be between 500 or 600 hp thanks.
schmitty- Posts : 4538
» need help budget build 460
» Low Budget/Experience Build?
» Budget build questions
» 71' 429 budget build info
» Street build 2,000-3,000 budget
