need help budget build 460
need help budget build 460 Empty need help budget build 460
Post  fatal addiction March 25th 2013, 10:15 pm
OK guys Im thinking about doing a budget build 460. I've never built a stock based 460 only 460's I've messed with is 600 plus" c-headed and Thor headed. I'm thinking about a 540 maybe 572 if I can get that done with stock block? My question is what's the best block and heads to start with? I'm hoping to get a max afford deal cheap as possible...lol it will be in a mud bog truck. Thanks
fatal addiction
fatal addiction
need help budget build 460 Empty Re: need help budget build 460
Post  DanH March 27th 2013, 10:08 pm
fatal addiction wrote:OK guys Im thinking about doing a budget build 460. I've never built a stock based 460 only 460's I've messed with is 600 plus" c-headed and Thor headed. I'm thinking about a 540 maybe 572 if I can get that done with stock block? My question is what's the best block and heads to start with? I'm hoping to get a max afford deal cheap as possible...lol it will be in a mud bog truck. Thanks
max effort cheap .
sell yourself one of the 600+ cube engines for a dollar.
Just had to post that, couldnt pass that up. lol
DanH
Post  schmitty March 28th 2013, 10:36 am
Are you cylinder head limited? A good place to start would be a good D9 block with a sonic check. I had one that would have gone to a 4.5" bore, and they can be found, but they are less than 10%. With a set of good DOVE heads on a 552, I had a stout drag engine that would keep up with most stuff around here.
Post  69F100 March 28th 2013, 12:30 pm
schmitty wrote:Are you cylinder head limited? A good place to start would be a good D9 block with a sonic check. I had one that would have gone to a 4.5" bore, and they can be found, but they are less than 10%. With a set of good DOVE heads on a 552, I had a stout drag engine that would keep up with most stuff around here.
My d9 I am using for the 552 is good for .100
Post  dfree383 March 28th 2013, 12:43 pm
"Max Effort" and "Cheap" typically do not go well together.............
What are the rules and what the budget?
Post  fatal addiction March 28th 2013, 7:49 pm
Not really any limitations I just want to build a bad ass 460 with a stock block and stock heads? I don't know y prob. Cause I've never used stock components? More curious than anything how good I can make one run.
fatal addiction
fatal addiction
Post  fatal addiction March 28th 2013, 7:53 pm
[quoSornH"][quotconfused addiction"]OK guys Im thinking about doing a budget build 460. I've never built a stock based 460 only 460's I've messed with is 600 plus" c-headed and Thor headed. I'm thinking about a 540 maybe 572 if I can get that done with stock block? My question is what's the best block and heads to start with? I'm hoping to get a max afford deal cheap as possible...lol it will be in a mud bog truck. Thanks[/quote]
max effort cheap .
Just had to post that, couldnt pass that up. lol[/quote]
??? Sorry kinda confused??
fatal addiction
fatal addiction
Post  DanH March 28th 2013, 10:08 pm
fatal addiction wrote:[quoSornH"][quotconfused addiction"]OK guys Im thinking about doing a budget build 460. I've never built a stock based 460 only 460's I've messed with is 600 plus" c-headed and Thor headed. I'm thinking about a 540 maybe 572 if I can get that done with stock block? My question is what's the best block and heads to start with? I'm hoping to get a max afford deal cheap as possible...lol it will be in a mud bog truck. Thanks
max effort cheap .
??? Sorry kinda confused??[/quote]
you want cheap . I'll make it simple to understand - sell me one of your 600+ Thor head engines for $1 (one dollar) and I will sell it back to ypu for a $1K . then you can say look what i got for a thousand bucks.
that way you won't have to deal with yourself for that $1 sale
DanH
Post  fatal addiction March 28th 2013, 10:31 pm
Huh so me asking about what block and heads to use turned into somebody wanting me to sell our 632 Thor motor for 1 dollar???? Thanks guys for the actual helpful posts.
fatal addiction
fatal addiction
Post  fatal addiction March 28th 2013, 10:34 pm
Smitty looked through the pile of blocks I have a d9 have to get it checked out.. thanks
fatal addiction
fatal addiction
Post  schmitty March 28th 2013, 11:18 pm
Slap a 4.5" crank in there with a good set of early heads, a Victor or Mafia intake, one of Lem's roller cams, and an 1150 or 1250 QFX and go kick some butt
