Boss 429 Cam Tunnel Plug
Boss 429 Cam Tunnel Plug Empty Boss 429 Cam Tunnel Plug
Post  enginetech April 18th 2021, 5:01 pm
OI noticed the rear of this Boss 429 block in my shop has a couple of tapped holes near the rear of the cam tunnel.  Was a bolted plug used for these blocks?  I can find nothing on the subject online.
enginetech
Boss 429 Cam Tunnel Plug Empty Re: Boss 429 Cam Tunnel Plug
Post  Paul Kane April 18th 2021, 7:06 pm
As viewed from the rear of the Boss 429 engine block, the four passages/holes alongside the cam tunnel (two passages on each side) should be 3/8-NPT pipe thread and plugged with a 3/8-NPT pipe plug.
Post  BOSS 429 April 18th 2021, 11:58 pm
from factory no, but Nascar guys sometimes ran a plate over the rear cam plug. and other racers, be sure to install the correct restrictors in the block if you are building one.
