Installing new solid roller lifters?
Soak in oil or not before installing them?
Mark Miller- Posts : 1959
Re: Installing new solid roller lifters?
Mark Miller wrote:Soak in oil or not before installing them?
From memory it was soak in a solvent to dissolve assembly grease/lube , then soak in synthetic oil
Gregaust- Posts : 626
Depends upon that manufacturer recommendation.
Some have a special lube in the roller & axle for initial run-in so, with those, just a dunk in oil before assembly.
Thanks guys and Randy FWIW they're Comp Cams Solid Roller Lifters!!
» BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» hydraulic roller cam with solid roller lifters
» JT557 HERE NEED SOLID ROLLER LIFTERS FOR ROLLER CAM
» fe solid roller lifters in a 460
