TCI reverse manual tbrake vb issue
TCI reverse manual tbrake vb issue Empty TCI reverse manual tbrake vb issue
Post  HorsinAround November 12th 2021, 4:24 pm
I built a full roller C6 beefed up to handle alot more power. I then installed a used but cleaned TCI reverse manual vb with a brake. When I went to the track and tested it last week, it would apply the brake at idle, but would jump 2-4 ft if I brought the rpm up to where I want to launch. Does anyone have an idea what the cause could be?
My primary trans has a Broader Performance tbrake vb and I haven't had any issues with it.
Alan
http://www.frontpagefab.com
Gregaust likes this post
TCI reverse manual tbrake vb issue Empty Re: TCI reverse manual tbrake vb issue
Post  Gregaust November 13th 2021, 6:01 am
Those TCI valvebodies are just trouble . Frank has a fix for them which may help your issue?
Gregaust
Post  Frank Merkl November 17th 2021, 4:28 am
essayist fix , that it out and set it on a concrete pad and take 12 lb sledge hammer and pound the piss out of it and throw it in the recycle bin !!!! it will save you 1000's of $
Gregaust and Mark Miller like this post
Post  HorsinAround November 17th 2021, 4:10 pm
Frank Merkl wrote:essayist fix , that it out and set it on a concrete pad  and take  12 lb sledge hammer and pound the piss out of it and throw it in the recycle bin !!!! it will save you 1000's of $
That is the plan. This trans is coming back out and the other one is going back in. Then the tci vb will become batting practice..
Post  Dave De March 9th 2022, 10:56 am
I know its an old post but when using a TCI VB you must plug the servo drain for it to work properly. Broader VB's this is not required. Not promoting TCI here.
I had a TCI build that I replaced the VB with a Broader piece but didnt open the servo drain. It shifted super hard and blew the servo o-ring. Once the drain was opened all went well.
TCI=Total Crap Inside
