Crane Cam Question
Crane Cam Question
Anything wrong with this cam? Is there any reason you wouldn't run it in a 460 or even a stroker in a street/strip, fairly heavy vehicle?
Specs.: 282/292 advertised, 246/256 @.050 .563/.580 lift, 108 LSA
It's a solid flat tappet.
I ran this in a mild compression 466 years ago in my old '79 F100 and was pretty happy with the way it ran.
It seems like someone, I think on one of these forums, said it wasn't a very good design for the 429/460 engines.
What do you guys think?
1EFF100- Posts : 265
Re: Crane Cam Question
The duration is about 10 degrees too high for your application thinking that the compression is below 10 and it has exhaust manifolds and a converter stall around 2400.
Probably it would be perfect with a 4.5" stroke crank.
Dave De- Posts : 797
1EFF100 likes this post
Dave De wrote:The duration is about 10 degrees too high for your application thinking that the compression is below 10 and it has exhaust manifolds and a converter stall around 2400.
It definitely was below 10-1 compression but the truck did have headers and a 3000 stall. Now that I think about it, pretty sure I installed it 4 degrees advanced--or whatever the 3 way crank sprocket was equipped with.
1EFF100 wrote:Dave De wrote:The duration is about 10 degrees too high for your application thinking that the compression is below 10 and it has exhaust manifolds and a converter stall around 2400.
Probably best to degree that cam in with a wheel and set it at 106 ICL.
1EFF100 wrote:Anything wrong with this cam? Is there any reason you wouldn't run it in a 460 or even a stroker in a street/strip, fairly heavy vehicle?
This is smaller than the size camshaft run in the Ford Racing B460 crate engine, M-6250-C460 hydraulic lifter cam.
Being that it is a solid lifter it would run very similar to the smaller M-6250-A443 hydraulic lifter camshaft used in the lesser E460 crate engine. It is a 108 separation instead of a 112 separation so, it will idle rougher with less vacuum.
M-6007-B460 = 10.5/1 compression, single plane intake manifold, 535 horsepower
M-6007-E460 = 10.5/1 compression, dual-plane intake manifold, 486 horsepower
Mark Miller and 1EFF100 like this post
» Crane roller rockers new price SOLD
» Crane Cams
» Crane valve spring??
» Crane Cams
» Crane Cams
» Crane Cams
