T&D rockers - head stud clearance
2 wicked
T&D rockers - head stud clearance Empty T&D rockers - head stud clearance
Post  2 wicked February 22nd 2022, 10:31 pm
Hey all, working on the new engine and came to a cross road. We have TFS a460 3x casting heads, t&d rockers, arp head studs, I new there was going to be some clearancing to to. But it seems like more than it should be. The int stands clear all the studs but one on each head. Near #1 and #8 int . The stands are one piece int . If I shorten the head stud and nut, there will only be about half the nut left vertically. Not good!! Should I clearance the int stands instead? Then all the exh stands hit the head stud nuts in the relief already machined into the stands. But do not hit the top of the studs, plenty of clearance there. Need to remove .060-.080 of material radially on the relief. Has anyone ran into this before? Might have to call T#D and check with them. Thanks cory
2 wicked
T&D rockers - head stud clearance Empty Re: T&D rockers - head stud clearance
Post  dfree383 February 24th 2022, 8:03 am
I’ve had an issue on C heads, just machined clearance in the stand.
Post  2 wicked February 24th 2022, 7:40 pm
Thanks for the reply, called T&D and they said that TFS doesn't machine the head stud pockets deep enough. Had a feeling before I called it would be the other guys fault!!! LOL. Oh well, just have a few hrs with the die grinder. Thanks cory
2 wicked
Post  rmcomprandy February 24th 2022, 7:47 pm
Whenever you get mating parts from 2 or more aftermarket companies, you have to proceed with the mindset of "nothing fits".
cool40, Mark Miller, 68galaxie and Dave De like this post
Post  cool40 February 25th 2022, 12:43 am
I had to cut my studs off to clear ww stands. Bigger problems with push rod clearance than anything else.
Post  Mark O'Neal February 25th 2022, 2:45 pm
Once again......the definition of "bolt on" is "you don't have to weld it.".......usually.
Mark O'Neal
dfree383 and Mark Miller like this post
Post  2 wicked February 26th 2022, 6:53 pm
Well, things went pretty good, got the intake and exh stands clearanced. Only took 4 hrs, just took a little off at a time. Then measured for pushrods, checked 3 times and ended up with 9..070 int and 9.484 exh. Still have to check piston to valve. Forgot the modeling clay at home. Check that tomorrow.
2 wicked
Post  68galaxie May 9th 2022, 11:34 pm
You are lucky you don't have to also weld tie bars to the individual rocker stands - like T&D for A429 heads.
I also had to shorten the head studs a little (in a lathe) and used 12 point nuts.T&D rockers - head stud clearance Imgp6012
68galaxie
68galaxie
