new build460, forgot to put oil shaft in !!
my certified Ford retired brother says this would happen in his shop once in awhile, he said they had hacks to replace from top. anyone on here have this trick up there sleeves ?
RANCHEROMAC- Posts : 13
Re: new build460, forgot to put oil shaft in !!
Yes has been many years since I had to help a "friend" with this find tube that shaft has to to be hand pressed into-tight fit, OD smaller than distributor guide hole, slip shaft down and rotate until you feel it drop and then drag when turning. Use a rod that fits thru the tube to push shaft down while pulling tube free.
As pointed out below yes remove the collar....
Kobelco- Posts : 101
RANCHEROMAC likes this post
RANCHEROMAC wrote:my certified Ford retired brother says this would happen in his shop once in awhile, he said they had hacks to replace from top. anyone on here have this trick up there sleeves ?
I have used another way:
Take the clip off the rod and then get a 5/16" thin wall, deep, 1/4" drive socket with 10 inch extension, use a sticky wheel bearing grease on the bottom of the rod and a lighter grease on the top of that rod and insert the top of the rod into the socket. Be sure that top side grease holds the rod in the socket. Then, slowly and carefully insert that rod down the distributor hole and into the oil pump.
Then, after the drive shaft has gone into the oil pump and is inserted all the way, hold the socket with a long, right angle pliers or spark plug boot pliers to remove the socket drive extension. Use carb cleaner to spray all the grease from inside the socket ... re-insert the socket drive extension and carefully remove the socket.
The Mad Porter, RANCHEROMAC and Kobelco like this post
Best to remove the pan and pump and install it with the clip, but it can be installed like Randy said.
You remove the distributor later and could be in for major surgery then when the shaft is in the pan.
QtrWarrior and RANCHEROMAC like this post
how about shaft top on bottom of distributor all as one
Kobelco wrote:Yes has been many years since I had to help a "friend" with this find tube that shaft has to to be hand pressed into-tight fit, OD smaller than distributor guide hole, slip shaft down and rotate until you feel it drop and then drag when turning. Use a rod that fits thru the tube to push shaft down while pulling tube free.
» IDT Eliminator 900 Series A460 Heads
» 428 fe help
» Going racing this weekend
» Crites header fitment
» New TNT 7-30-10 results
» 428 fe help
