filled block weight
filled block weight
Has anybody done a weight comparison of a filled to bottom of water pump hole block VS a non filled block with just water in it? Ive got a DOVE'A block i'm going to be putting 4 bolt caps on, and was also wondering what the concensus is on what power level a guy needs to fill one anyway? It'll be a .060 over or less when built if that helps.
fordmonsta- Posts : 236
Re: filled block weight
Dave McClain did a comparison like this once.
Kobelco- Posts : 101
Whatever the block weighs....+ 30 lbs!
BBFTorino- Posts : 999
» Can you run a filled block on gas
» Boring with a filled block
» Block weight
» Moving block back for weight transfer?
» C6 filled tube plug
» Block weight
