Boring with a filled block
Boring with a filled block Empty Boring with a filled block
Post  HorsinAround October 12th 2016, 1:26 pm
Would a filled block allow for a slightly bigger bore then a non filled block? I took a block in on trade that is bored .040 over that the guy said he had it sonic checked and was told it could go .060 safely. He then filled the block and ran it in his pulling truck. So, I am curious if it could go .080 over since its filled.
http://www.frontpagefab.com
Boring with a filled block Empty Re: Boring with a filled block
Post  rmcomprandy October 12th 2016, 6:40 pm
HorsinAround wrote:Would a filled block allow for a slightly bigger bore then a non filled block? I took a block in on trade that is bored .040 over that the guy said he had it sonic checked and was told it could go .060 safely. He then filled the block and ran it in his pulling truck. So, I am curious if it could go .080 over since its filled.
Just because a block is able to be bored .060" oversize or even more does not mean it is as strong as it would be when it is also filled.
Filling a block essentially keeps the bores from moving around under power for a better ring seal and has very little to do with how much oversize that particular block can be machined.
Post  HorsinAround October 12th 2016, 9:13 pm
That was my thoughts as well, but i was curious so I threw it out there.
