Cyl wall thickness 40psi methanol
Cyl wall thickness 40psi  methanol Empty Cyl wall thickness 40psi methanol
Post  Kobelco August 16th 2023, 6:36 pm
Ok stock D9 block w girdle what is the minimum wall thickness you 385 gurus would run 40 psi roots, 8.5-1 static and methanol fuel. Rotating will be forged.
Kobelco
Cyl wall thickness 40psi  methanol Empty Re: Cyl wall thickness 40psi methanol
Post  BBFTorino August 18th 2023, 1:13 pm
40 PSI....wow! I wouldn't go less than .175" just my opinion.
Kobelco likes this post
Post  rmcomprandy August 18th 2023, 4:21 pm
Kobelco wrote:Ok stock D9 block w girdle what is the minimum wall thickness you 385 gurus would run  40 psi roots, 8.5-1 static and methanol fuel.  Rotating will be forged.
.150" if it is only a few localized spots.
QtrWarrior and Kobelco like this post
