632 SR71’s
632 SR71’s
4.600 x 4.750 , 6.800 Oliver rods, Callie’s billet crank. Erson solid roller cam 16:1 Racetec gas ported pistons, Danny Bee belt drive, Kaase wet sump pump, Innovators West Damper. I’ll be testing a custom built from a long runner TFS Tunnel Ram (Holmes) with (2) 1450 carbs on Q16. I’ll also test with a Venom intake and a single big bore carb. Engine has ported SR 71’s on it. Headers are custom built front exit 2 3/8 primary and 4.500 collector.
IDT572- Posts : 11
dfree383 likes this post
Re: 632 SR71’s
Was Blue Four Eyes involved with it?
Sounds like a nice engine.
supervel45- Posts : 4498
Re: 632 SR71’s
Yes that’s what it’s going in, plus a 500 lb weight reduction
IDT572- Posts : 11
Re: 632 SR71’s
^HellYea. Post Her Up when you GetRDune!
IDT572 likes this post
nice
sounds like a big hp build.cant wait to see dyno results.whats it going in?
hbstang- Posts : 365
Re: 632 SR71’s
86 notch Mustang don’t know how to post a picture
IDT572- Posts : 11
sr71 heads
what kinda of numbers are you looking for?
Re: 632 SR71’s
1200hp 900 tq!!!! Hopefully
IDT572- Posts : 11
nedceifus likes this post
Re: 632 SR71’s
IDT572 wrote:4.600 x 4.750 , 6.800 Oliver rods, Callie’s billet crank. Erson solid roller cam 16:1 Racetec gas ported pistons, Danny Bee belt drive, Kaase wet sump pump, Innovators West Damper. I’ll be testing a custom built from a long runner TFS Tunnel Ram (Holmes) with (2) 1450 carbs on Q16. I’ll also test with a Venom intake and a single big bore carb. Engine has ported SR 71’s on it. Headers are custom built front exit 2 3/8 primary and 4.500 collector.
Quit Teasing and Spill the Beans.
What Did the Heads Flow?
.900" Lift Cam, or How Close to that?
Inquiring Minds Want to Know.
Re: 632 SR71’s
I got 486 before I did the chamber blending, I usually pick up 8-10 more. But I never went back to the bench. Flow peaked at .840 lift, same as the cam .840 at the valve with lash.
IDT572- Posts : 11
Re: 632 SR71’s
Nice! I Don't see 1,200 Being a Problem.
You Gonna End up Like Ritcher, More HP Then Suspension. I am Sure You will Address that too, if Need Be.
Needs a Plate and 3 Foggers Next.
Re: 632 SR71’s
^ Hey Hey HeyHey! Buckleup/Strap in Tight!!! I see 6's in your Future if You get That ShitBox to Plant Hard.
Freaking Pontiac Reverse Bore and Stoke C'Mon My If it Work's Hell Yea Baby
Re: 632 SR71’s
^ Just for The Record.
This Legendary Recent FAST Series 1971 Mustang SCJ Clone had a 4.45"BoreX4.75"Stroke 588 with a 2 Bolt OEM Block Converted to 4 Bolt Splayed Main Caps and Worked OEM CJ Heads.
825HP Through Factory Ported Exhaust Manifolds and Exhaust with a Ported SCJ Intake with a Big VS Holley 4150
https://www.hemmings.com/stories/article/stopgap-stang-1971-ford-mustang-mach-1
So The OP's will Make It Look Like A Toy in a Fly Weight Prepped Chasis.
Re: 632 SR71’s
supervel45 wrote:^ Just for The Record.
Thanks for the link i don't think i've seen that article before that car was fast for sure and IMO the Mopar and GM rule makers ran him out of the class!!
Mark Miller- Posts : 1958
Re: 632 SR71’s
^ Your Welcome Mark.
You May Have seen it, or maybe you missed it? I linked it a few years ago and I believe not too long ago again.
That 1971 SCJ Mustang Clone and Our Big Black 9 Second Texas 612BBF Land Yacht are My Favorite Fords.
Re: 632 SR71’s
Been busy porting heads and building engines!!! I have everything together for the 632 just need to assemble. Hope to get on it in a week or two. I’ve got a 534 ready to assemble right beside it , prob do both at the same time.
IDT572- Posts : 11
Re: 632 SR71’s
BLADE size on those 1450's?
BOSS 429- Posts : 2372
Re: 632 SR71’s
IDT572- Posts : 11
Re: 632 SR71’s
BOSS 429 wrote:IDT572 wrote:4.600 x 4.750 , 6.800 Oliver rods, Callie’s billet crank. Erson solid roller cam 16:1 Racetec gas ported pistons, Danny Bee belt drive, Kaase wet sump pump, Innovators West Damper. I’ll be testing a custom built from a long runner TFS Tunnel Ram (Holmes) with (2) 1450 carbs on Q16. I’ll also test with a Venom intake and a single big bore carb. Engine has ported SR 71’s on it. Headers are custom built front exit 2 3/8 primary and 4.500 collector.
I believe there 2.250 blade. !!!
IDT572- Posts : 11
» The new SR71 heads
» SR71 and Godzilla...
» Kasse SR71
» Sr71 heads!
» Kaase K1 cam vs. K2 cam in 521 with SR71 heads?
» Kasse SR71
» Sr71 heads!
