Foxbody 460/C6 swap and engine build help
Fox460C6
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Foxbody 460/C6 swap and engine build help
What you have above I'm sure will work , but if you want budget budget . About 10 years ago a friend of mine took a mid 70s 460 out of an rv that was a good runner and put new rings and bearings in it . No machine shop needed and he did it himself .
Slapped a torker intake or performer rpm if I recall with a mild cam and timing set . Longtube headers , c6 had a 2800 stall convertor . Had an 850 carb .
Was in a capri and on street and that thing ran hard for what it was . It went in the mid 12s at track and later it got a 125 shot of nitrous on a plate and ran 10.90s and lasted a long time .
This was all low buck and he had a lot of fun . Just depends on what you want to do and how far you want to go . Machine shop costs to bore a block and all . Weather it's mild or 700hp build will be same keep that bin mind
Andy
Andy
5pointslow- Posts : 1408
rmcomprandy and Mark Miller like this post
» 460 swap in a foxbody?
» Foxbody swap headers
» best oil pan to use with engine plates foxbody mustang ?
» engine swap
» engine swap
Page 3 of 3
