Carb pad lifting eye
manofmerc
Gregaust
Carb pad lifting eye Empty Carb pad lifting eye
Post  curiousgeorge January 2nd 2024, 11:18 pm
Will one of the carb pad lifting eye hold an aluminum head/intake 460 and a C6? My leveler is hitting the firewall before I get the engine far enough back.
curiousgeorge
Carb pad lifting eye Empty Re: Carb pad lifting eye
Post  rmcomprandy January 2nd 2024, 11:50 pm
curiousgeorge wrote:Will one of the carb pad lifting eye hold an aluminum head/intake 460 and a C6?  My leveler is hitting the firewall before I get the engine far enough back.
I have used a simple carb pad lift plate with an iron headed 460 having a C4 attached,
with no issue.
curiousgeorge and Mark Miller like this post
Post  Gregaust January 3rd 2024, 5:39 am
There were some tests getting around some time ago , those lifting pads took near 9000lb before failure .
Gregaust
curiousgeorge likes this post
Carb pad lifting eye Empty welders
Post  manofmerc January 3rd 2024, 6:05 am
Dont worry I built myself a couple of these .I made them a bit longer so I could have four holes .To have different installation angles no problems after 20 years .I have been welding 40 years.Doug
manofmerc
Post  curiousgeorge January 3rd 2024, 9:16 am
I have one ordered. Thanks all!
curiousgeorge
Post  427John January 9th 2024, 8:10 pm
I know it looks sketchy but I've never had any trouble with them just make sure the nuts or bolts are tightened good.
427John
Post  HAP2 January 10th 2024, 7:17 pm
I use this type
Carb pad lifting eye Pivot10
HAP2
Post  Mark Miller January 11th 2024, 12:36 am
HAP2 wrote:I use this type
Looks nice but expensive!!
Post  HAP2 January 11th 2024, 2:25 pm
It is both. Mostly Nice! Multiple removals/installs of 572 using this tool.
R,
HAP
HAP2
