camshft specs
camshft specs
ra 235-430-14 camshaft is the number on it cam motion . any idea what specs this cam is .? thanks
maverick172- Posts : 205
Re: camshft specs
i got the specs from cam motion it is amaverick172 wrote:ra 235-430-14 camshaft is the number on it cam motion . any idea what specs this cam is .? thanks
Solid Roller: .024'' Hot Lash
285/285 Duration @ .050''
114 LSA, 110 ICL (114+4)
.430''/.430'' Lobe Lift
what you guys think for a turbo motor ?
Re: camshft specs
That seems like alot of camshaft if you intend to drive it on the street much. The single pattern should help build boost. I have seen turbo cams with less exhaust duration then intake also for that. The some what wide LSA angle is good also.
You could summit your combo to CamKing and see what it comes out like.
http://jonescams.com/drag-race/
supervel45- Posts : 4499
Dave De likes this post
Re: camshft specs
maverick172 wrote:i got the specs from cam motion it is amaverick172 wrote:ra 235-430-14 camshaft is the number on it cam motion . any idea what specs this cam is .? thanks
What engine size ... is it a race engine or something else ???
Re: camshft specs
Get something ground for the application.
» 514 blower build question
» Some questions on 429 swap into 79 f150
» tig and sfi specs
» Need Help build questions
» help with cam specs
» tig and sfi specs
