Glide Leak
Glide Leak
I had a very small drip from my pan. Mainly just when the car was hot and I would see it on the floor of my trailer. So the other day I just checked the bolts and tighten them just a bit and now I have the worst leak you have ever seen. Anyway I plan to put on a new gasket to see if it will correct the issue. Should have just left well enough along !
valleydawg- Posts : 427
Re: Glide Leak
Steel or aluminum sheet pan or cast aluminum?
jbozzelle- Posts : 3705
Re: Glide Leak
I don't like the cork gaskets so I stay away from them. I don't know what you had but if your buying something different keep in mind that the rubber gaskets hold up better. Also I have seen some people put some silicon on the gaskets and let it dry completely before putting it on the tranny. I don't do that but I have a very thick billet railed pan to help with the seal.
whatbumper- Posts : 3024
Re: Glide Leak
It is a cast pan. I have a couple of rubber gaskets on the way. Thanks
Re: Glide Leak
I don't recall if there is an actual torque spec for the pan, but if there is I would follow it. Too tight is almost as bad as too loose.
Nevs- BBF CONTRIBUTOR
Re: Glide Leak
To tight is bad...I know that for sure!
Re: Glide Leak
I don't use any torque specs other than using a 1/4 inch rachet and tightening until "snug".
Re: Glide Leak
Use Accopac or Farpak gaskets and no sealer. Torque to 95 in/lbs. Retorque after some use. If you want to be slick about things dab a thin coat of trans assembly gel lube on each side of the gasket. It'll seal up fine. Some cast pans I've seen have been porous so watch for that. Also watch for a leak source above the pan rail; cooler line fittings/etc. Those can run down and make it look like a leaky pan!
Oldani- Posts : 46
» need help with a leak
» belhousing and glide or glide parts
» leak
» Oil Leak
» Front plate/water issues
» leak
» Oil Leak
