SCJ bowl ported potential
+7
86 coupe
11 posters
SCJ bowl ported potential Empty SCJ bowl ported potential
Post  86 coupe January 25th 2010, 6:28 pm
was wondering about the flow and horsepower potential of a set of scj heads with a good bowl port and gasket match. engine is a 545 with 11.7 compression victor/ with dommy and a roller cam. have started the parts buying process and am already commited to this combo but really would like some outside opinions.
thanks craig
86 coupe
SCJ bowl ported potential Empty Re: SCJ bowl ported potential
Post  the Coug January 25th 2010, 6:31 pm
more compression...... these engines like compression.....
Post  Nevs January 25th 2010, 6:34 pm
Only way to know what they flow is to flow them. Depending upon who did the work, they could be good or not so good... Just making things "big" isn't the answer.
Post  rmcomprandy January 25th 2010, 6:41 pm
the Coug wrote:more compression...... these engines like compression.....
YEA ... 11.7/1 is about useless.
To high for gas at the pump and not enough for race gas ... I guess you could mix it.
IF the bowl porting is done correctly then there is more than 350 CFM at only .500" valve lift and around 370 CFM maximum on the intake with about 220 CFM maximum on the exhaust side.
Post  86 coupe January 25th 2010, 6:48 pm
thanks the compression is a compromise, the motor will get a 200 shot after the chassis is sorted out and i don't want it too high because of my limited tuneing ability
86 coupe
Post  IDT-572 January 25th 2010, 7:05 pm
The SCJ's respond to bowl porting better than any heads I have ported,, ,,,, ( except for the Pro-Comps ) Embarassed Can't believe I posted that.
Also to add to what Randy M said, that max intake flow number will be around .570 lift also.
Post  bbf-falcon January 25th 2010, 7:19 pm
IDT-572 wrote:The SCJ's respond to bowl porting better than any heads I have ported,, ,,,, ( except for the Pro-Comps ) Embarassed Can't believe I posted that.
Blake, YOU GO TO TIMEOUT YOUNG MAN. WE WILL NOT TOLERATE SUCH TALK IN THIS HOUSE Embarassed Sad Shocked Smile
Post  schmitty January 25th 2010, 7:56 pm
Yep Dutchlincoln is the only guy who has the knowlege to post anything about them P/C heads. He da man queen geek
Post  dfree383 January 25th 2010, 9:12 pm
Aluminum scj's or iron factory ones?
Post  Lem Evans January 25th 2010, 9:22 pm
dfree383 wrote:Aluminum scj's or iron factory ones?
I prefer the bronze ones .
Post  dfree383 January 25th 2010, 9:28 pm
Those are out of my price range!! Laughing
SCJ bowl ported potential Empty To CJ or not to CJ, is that the super question?
Post  LivermoreDave January 25th 2010, 9:47 pm
Just a thought! Lem what did those cast iron CJ heads of David Morehead flow that performed so well?
Dave.
LivermoreDave
Post  Lem Evans January 25th 2010, 10:51 pm
LivermoreDave wrote:Just a thought! Lem what did those cast iron CJ heads of David Morehead flow that performed so well?
Dave.
Not as good as was thought after it was found to have NOS plumbed under the tunnel ram . I'd guess that may have something to do with the split cyl. walls and the cracked Byrant crankshaft.....NOS is free power you know...you just gotta buy the parts Smile
Post  the Coug January 26th 2010, 9:32 am
86 coupe wrote:thanks the compression is a compromise, the motor will get a 200 shot after the chassis is sorted out and i don't want it too high because of my limited tuneing ability
first of all if you have a limited tuning ability, you should be asking yourself one Question, should you be building an engine and racing it????? Because Tuning is 75% of it after you build it or Have it built then you have to have some kind of Idea what you are doing or Boom you detonate it or what ever and all the rods hang out the bottom of the Block.....
so I would suggest getting a book or with someone and learning how to tune an engine.... really fast.... affraid
Post  86 coupe January 26th 2010, 12:54 pm
hey coug i agree that a big boom may happen. i have raced for most of my life but haven't in about 12 years, also have only made one nitrous pass in my life, but you can only learn by asking, reading or doing , and im tired of books and talking. by the way thanks everyone for your input
86 coupe
Post  D. Sea January 26th 2010, 1:18 pm
You can still run Nitrous with more compression Idea
If you bump up the compression to 13-ish to 1 then you may not want or need Nitrous What a Face
D. Sea
D. Sea
Post  86 coupe January 26th 2010, 1:30 pm
Damon i agree that it would run fast enough with out it, but i already have the parts so for this motor i'm stuck
86 coupe
Post  D. Sea January 26th 2010, 1:32 pm
86 coupe wrote:Damon i agree that it would run fast enough with out it, but i already have the parts so for this motor i'm stuck
gotcha, you already have the pistons... Sounds like me, run what you've got........ unless you could sale them and get flat tops Idea
D. Sea
D. Sea
