mid plate problem plz help!!
+9
342g
56Tbird
DFI429
521fox4eye
D. Sea
Big block fox 339
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Ok im finally ready to put my fox together im running d&d headers and motor plates. The mid plate on the passenger side aint even close to fitting trimming wont help what should i do thanks for the help
Big block fox 339- Posts : 279
Re: mid plate problem plz help!!
gonna have to trim it, wont be much left worth mounting after your done. I'd weld a tab on the plate in a different spot. i even like to put a tap on the top and run spacers through the firewall, tie it into the rollcage............damn stout that way...lets the midplate do its job and distribute the power to the chassis.
In the process of doing this on our smallblock fox mustang, should be able to get some progress pics by the weekend.
cool thanks only thing is im not running a roll cage yet its a street car the way it looks to me trimming it wont work...... big thanks to bob at d&d these hearders are awesome if it wasnt for the mid plate problem it would b smooth sailing
I think you're gonna have to make a new mid plate. Should look similar to this
I trimmed mine to fit the headers first and then the chassis. Actually I made a cardboard template and trimmed it FIRST then transfered it over to the metal plate and then cut/trim...
D. Sea- Posts : 2768
Thanks that looks good what kind of plate did you cut that out of how thick Just regular sheet metal ?
Big block fox 339 wrote:Thanks that looks good what kind of plate did you cut that out of how thick Just regular sheet metal ?
It started out as a midplate from Bob at D&D but it's a "trim to fit deal" and is one big square with the holes already cut to fit the bolts and dowel pins.
we ran the same set up and had to do the same thing,tried 3 different plates before we got it right,the mid plate was the toughest part of the swapD. Sea wrote:Big block fox 339 wrote:Thanks that looks good what kind of plate did you cut that out of how thick Just regular sheet metal ?
521fox4eye- Posts : 23
Thanks for the ideas guys i got my template made gonna make the mid plate tomorrow. I got one more question what kind of mount did yall use due to the mounting holes being so much higher
Big block fox 339 wrote:Thanks for the ideas guys i got my template made gonna make the mid plate tomorrow. I got one more question what kind of mount did yall use due to the mounting holes being so much higher
Why not just utilize the plate you have & cut the passenger-side ear off & re-locate it? That way you retain the bolt & dowel pin holes, and can put the mount holes/tab where you need them..
Just thinking outside the cashbox
I have "L" type brackets that attache to the frame and then bolt to the midplate. Sorry, don't have pictures of those brackets.
Just thinking outside the cashbox [/quote]
Yeah thought about that but the metal for the new one wasn't but 17 buck so I went that route
here is mine but i also had to trim a buch on the pass side for the kooks to work ... i tried to copy Damons deal
Good picture Nick,
If you guys look really close, you can see the brackets that are bolted THROUGH the frame. One day while Bill was over helping with the anti-roll bar, he tig welded some nuts on the backside of the brackets. Makes installation MUCH easier
Edit:
339,
You may have to trim a little bit more on the drivers side to clear the steering shaft. You won't know until you get it test fitted in the car.
Edit:
339,
Thanks for the pic Mr. bruno... ive got those same L brackets but i dont think mine are gonna b high enough im just gonna fab whatever i need to make it work i hope to stick the motor and tranny in this weekend!!!!
No kidding ,you had to trim a bunch off of it :king:Looks like you got hammer happy on the fire wall toobruno wrote:
56Tbird- BBF CONTRIBUTOR
i get the feeling Dan did the trimming.
342g- BBF CONTRIBUTOR
Here is the one I modified for the smallblock, note the holes through the firewall behind the tab on the top, I had some steel dowls made that will go through the holes and weld into the cage structure. Just use some bolts to go through and tie it into the midplate.
Nice pic Jon.
Are you going to add some sliders for the plate to slide into position on?
jbozzelle- Posts : 3705
Anybody got any pics of how you mounted the Lat limiter bars ? This is my first car I'm learning And what about mounting a c6 what mounts are yall using. Thanks for the help I wouldn't b able to build a car without it !
jbozzelle wrote:Nice pic Jon.
I always leave the midplate in the car.
OK, how are you going to tie in that plate to the dash bar? Similar to your car? I plan to do the same to mine, but my dash bar runs striaght across from a-pillar to a-pillar right behind the instrument cluster...
similar to this...........I ran a bar across to the bars that go forward through the firewall.
What size rebar did you use on that gas pedal, Jon?
Greg_P- Posts : 1009
Greg_P wrote:What size rebar did you use on that gas pedal, Jon?
I used tubing, hollow in the middle.....lighter by a whole bunch.........
Gotcha. This whole time I thought that cross bar was the dash bar. My dash bar doesn't go that far forward. Not sure if the factory brake pedal assembly will allow a bar like that either.
Page 1 of 2 • 1, 2
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» Cam thrust plate and water pump baking plate questions
» BBF Starter Locator Plate and Steel Mid Plate
» Mid plate and motor plate for bbf ford-off set
» front motor plate and mid plate
Page 1 of 2
