mid plate problem plz help!!
+9
342g
56Tbird
DFI429
521fox4eye
D. Sea
Big block fox 339
13 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: mid plate problem plz help!!
There's room, a plasma cutter and tubing notcher are your friends.............
Alrighty I stuck the motor in what do yall measure to and from to square the motor in the car?
Big block fox 339- Posts : 279
I'll get after it once the Superbowl is over... Thanks for the pics agin, Jon.
jbozzelle- Posts : 3705
whats a superbowl?
richter69 wrote:whats a superbowl?
hmm maybe it's like a high performance toilet like a pro comp toilet or something
drop a plumb line off the front of your crank, trans tail shaft, then center of the pinion
nitro717- Posts : 92
cool thanks for the pics
More pictures here
https://s45.photobucket.com/albums/f75/Phantasea466/Big%20Block%20Fox%20Engine%20Plates/
D. Sea- Posts : 2768
Thanks for all the help I got the motor in today only one problem when I got the motor where I wanted it one header tube is touching the k-member not hard against it just touching will it hurt anything ?
Big block fox 339 wrote:Thanks for all the help I got the motor in today only one problem when I got the motor where I wanted it one header tube is touching the k-member not hard against it just touching will it hurt anything ?
"tweak" it a little and make it fit
D. Sea wrote:Big block fox 339 wrote:Thanks for all the help I got the motor in today only one problem when I got the motor where I wanted it one header tube is touching the k-member not hard against it just touching will it hurt anything ?
(BFH)
Alright got the header problem fixed tonight. Sorry I got one more question I'm a newb do I use the flexplate shield and the mid plate or just the mid plate?
I'd use just the midplate, its going to be thicker than the factory blockplate anyway. Make sure the converter spacing is ok.
Yeah the converter looks good this is my first time at this and I'm doing it alone so I was worried I needed to use both Thanks I coulnt do it without this site
Glad you was able to get a new plate made, I knew it wouldn't be a big step for a high stepper!
Note to everyone else: I am a fault for his first midplate. I had trimed it to fit my turbo Mustang build, as my headers where facing foward so I never looked at mid plate clearance for regular headers.
jones- Posts : 2230
That super fancy football game the New Orleans Saints won...
jones wrote:Glad you was able to get a new plate made, I knew it wouldn't be a big step for a high stepper!
ha the plate was no problem after i figured out i could just make it how i wanted it lol
I tried to keep mine to where both ears would bolt at the frame rail area/height. The driver's side is like this, but the pass side is like yours. I'll end up with the midplate bolting to the frame brackets about 3-4" higher than the framerail.
Page 2 of 2 • 1, 2
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» Cam thrust plate and water pump baking plate questions
» BBF Starter Locator Plate and Steel Mid Plate
» Mid plate and motor plate for bbf ford-off set
» front motor plate and mid plate
Page 2 of 2
