Valve clearance
jones
Larry Williams
Valve clearance
How much closer to the piston does the valve get with a 2 degree advance and a 4 degree advance?
Larry Williams- Posts : 884
Re: Valve clearance
Wouldn't that depend on your camshaft? Are you just trying to figure out how to tell before you adjust your camshaft?
jones- Posts : 2230
Re: Valve clearance
.007-.008 range per 1 degree.
feetfirst- Posts : 139
Re: Valve clearance
jones wrote:Wouldn't that depend on your camshaft? Are you just trying to figure out how to tell before you adjust your camshaft?
x2
I believe the duration and ramp speed functions would have an impact on the results but in any case you shouldn't have any problems assuming your have proper clearances now.
paulie9fingers- Posts : 134
Re: Valve clearance
Depends on the Cam, where the lobes are ground to start with...... Thiers no rule of thumb or anything like that, it needs to be checked.
Re: Valve clearance
I should have checked 4 advanced and 4 retarded when I assembled the motor. Good thing I want to pull the cam to double pin it before it runs. Might do the oiling mods at the same time if I have to pull the heads
Clearance
This was two years ago but, I checked mine from 20 degs BTDC to 20 degs ATDC in 2 degree increments. If I remember right I had to retard the cam 2 degrees and it gained about .015-.020" more clearance on the exhaust valve. The cam was a solid flat of 268/276 @ .050 with .658/.689" lift. I had already flycut pistons and needed additional clearance. Not optimun but it worked okay.
FWIW Mark
FWIW Mark
Last edited by Mark Laczo on February 4th 2010, 9:34 am; edited 1 time in total (Reason for editing : correction)
Mark Laczo- Posts : 274
» Going from Ferrea 2.20 valve to 2.25, Is there a better flowing valve for ported STREETS?
» valve cover studs for aluminum valve covers
» How do you check valve to valve clearance????
» Minimum valve to valve clearance
» Exh VAlve ?
» Exh VAlve ?
