need x bearings
need x bearings
useing acl's
i have a clearince of 2 1/10
should i use a half set of xbearings to get more ?
jesse- Posts : 447
Re: need x bearings
Not to familiar with the ACL's but unless they are a little on the tight side as a rule I would think you would be ok with just a full set of X brgs, Should put you in the .003-.0035 range. Good to go.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
Re: need x bearings
Yes....on your rods .jesse wrote:useing acl's
If it was the mains 3+ would be where you'd need to be .
Re: need x bearings
thanxs lem i will get with you or shawn mon and get a set on the way
jesse- Posts : 447
Re: need x bearings
2.6-2.9 seems to work on the rods. 3.0-3.1 will work but it's bigger than it needs to be .
What are you getting on the mains ?
Re: need x bearings
Me and Lem has been thru all this the last couple of weeks He's got me educated
Re: need x bearings
havent done the mains yet
gotta wait till i get it to the mach shop and borrow the tools
all i have is a dail calper
jesse- Posts : 447
Re: need x bearings
i didnt
the guy that balnced the motor did
i can all him mon and ask
but it might be a good idea for me to also check
the clearince and see if i come up with the same as he did
jesse- Posts : 447
» Are Kings HP good for a 521 stroker street strip?
» cam bearings
» rod bearing clearance
» 429 bearings
» cam bearings
» cam bearings
» 429 bearings
» cam bearings
