How much fuel to flow?
342g
torkair
How much fuel to flow? Empty How much fuel to flow?
Post  torkair February 8th 2010, 1:41 pm
I am looking into electric fuel pumps to feed my 460 build. Carb will be a 1050 dommy and max RPMs will be 7000. Not too sure on the GPH needed to feed something like this but I'm betting that it's gonna be up there.
torkair
torkair
How much fuel to flow? Empty Re: How much fuel to flow?
Post  bbf-falcon February 8th 2010, 1:50 pm
Well, It's according how you look at it imo. Lots of Racers go overboard on Fuel pumps. It has alot to do w/build. My Maverick ran 9.80's w/472. I shifted at 68 and it crossed line at 7. Roller cam,14.1 comp,4.30 gears. Holley Blue pump (110 gph). Never had a problem. But, a 557 would probably need a (140gph).IMO Smile
Post  richter69 February 8th 2010, 1:51 pm
cell location and plumbing need to be figured in the equation as well.
Post  342g February 8th 2010, 1:58 pm
Ijust happen to have two B/G 280's, if you are going to run gasoline. Smile
342g
342g
Post  dfree383 February 8th 2010, 4:30 pm
too big of pump doesn't hurt a motor....... too little and Lean it out...... different story. You need fuel to make power.
Post  jts557 February 8th 2010, 5:21 pm
Also the bigger the line the more pump you need as gravity pulls the fuel back when you are going down track.
If you run alky whole different ball game on pumps.
jts557
Post  IDT-572 February 8th 2010, 9:59 pm
I ran a malloy 140 on my 557 863 hp 5.60's 3000 lb. But it's got a big free flowing filter and sweeping free flowing fittings
Post  richter69 February 8th 2010, 10:06 pm
IDT-572 wrote:I ran a malloy 140 on my 557 863 hp 5.60's 3000 lb. But it's got a big free flowing filter and sweeping free flowing fittings
and was runnin out of fuel at the top end on the 1/4 mile passes................... Very Happy
Post  IDT-572 February 9th 2010, 10:30 am
That was a jetting problem there ( Mr A1+ ) Laughing
Post  dirtbogger February 9th 2010, 11:05 am
I was told by a local late model dirt track guy to run 1/2 fuel line, and test it by free flow. If it will fill a gallon jug in 15 seconds or less you should have enough fuel!, if not you need more volume! just what I was told, just a rule of thumb place to start I guess! Good luck! Smile
dirtbogger
Post  torkair February 9th 2010, 1:47 pm
I was thinking of running 1/2" braided line from the pump to the carb. I was also thinking of mounting the pump on the frame a few inches forward of the sending unit on the tank that way I have some wiggle room to install a filter in-line before the pump. Also any thoughts on pressure regulators or ways to protect the pump and filter from various road debris while driving to or from the track?
torkair
torkair
Post  richter69 February 9th 2010, 2:11 pm
what pump?
Post  torkair February 9th 2010, 4:05 pm
richter69 wrote:what pump?
That's what I'm trying to figure out at this point. My brother needed a 110gph mechanical pump to feed his 302 (before it died of course, lol). It kept sucking the float bowls of the 650 speed demon dry until he upgraded to the 110. This 460 is gonna want a heck of alot more fuel than that puny little 302 could ever burn!
torkair
torkair
Post  paulie9fingers February 9th 2010, 4:30 pm
Hey torkair, sent you a pm Very Happy
paulie9fingers
paulie9fingers
Post  dfree383 February 9th 2010, 4:51 pm
How Much HP? How Big of Motor?
Post  torkair February 9th 2010, 6:24 pm
Motor is gonna be a 460 w/ .030 overbore (466 IIRC) and my power goal is 600hp/tq. I'm wanting to hit mid 11 second passes on all motor using an M800 5speed (it's not out yet but I still want it) and 3.50 trak-lock gears. This is all going in a 72 Gran Torino Formal Roof with full interior (and hopefuly I wont need a cage either). Biggest problems I'm seeing are fuel starvation and getting the thing to hook off the line.
torkair
torkair
Post  richter69 February 9th 2010, 6:54 pm
one of them bg 280 pumps thats for sale here would work nice.
Post  dfree383 February 9th 2010, 8:29 pm
X2 you Definetly won't need anything bigger.
