Camshaft Degreeing question?
Camshaft Degreeing question? Empty Camshaft Degreeing question?
Post  Tennessee Bullitt February 14th 2010, 2:05 pm
I have degreed my custom cam Lem had designed for me and I have did it a couple of times, so far I have came out with a 110 center line. The cam card shows a 109 center line. I have the ford racing timing gear set. I figure I am going to leave it at what it is and be done with it, am I thinking right about the 1 degree not making a big difference?
Tennessee Bullitt
Tennessee Bullitt
Camshaft Degreeing question? Empty Re: Camshaft Degreeing question?
Post  rmcomprandy February 14th 2010, 3:02 pm
With all the dimension "stack-ups" involved, (crankshaft throw to keyway, bottom crank gear, chain irregulararities, top camshaft timing gear), I would say you got pretty lucky to have only 1 degree varience.
That is the reason for degreeing the cam, (to find out where it ACTUALLY is in THAT engine; correct it or leave it), otherwise simply installing it "dot to dot" would be good enough to begin with.
Post  c.evans February 14th 2010, 5:15 pm
Being in at 110* is not going to hurt anything. Like Randy said, that's pretty good considering all the room for errors to creep up.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Lem Evans February 14th 2010, 6:48 pm
At 110* the cam is retarded....install advanced.....106*ish. 109* is not the centerline...it's the lsa.
Post  Lem Evans February 14th 2010, 6:50 pm
c.evans wrote:Being in at 110* is not going to hurt anything. Like Randy said, that's pretty good considering all the room for errors to creep up.
Charlie
The cam being in retard is not helping anything per this application.
Post  c.evans February 14th 2010, 7:05 pm
Okay, advance it and put it on 106* like what Lem suggested. He knows the cam specs and the weight of the vehicle, etc. I don't.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Tennessee Bullitt February 14th 2010, 8:58 pm
Ok I will put it like you say Lem, I have the card here and it says lobe seperation is 109. It also say here "these specs are for cam installed @ 109 intake center line. Either way thanks for this cam Lem. So far this thing should be a monster. I am going to put it on an engine dyno and perfect the setup instead of guessing where it would be at.
Tennessee Bullitt
Tennessee Bullitt
Post  Lem Evans February 14th 2010, 9:27 pm
The card says what the events are if the cam is installed at 109*...straight up . It in no way says to install it there.
Post  Tennessee Bullitt February 14th 2010, 9:37 pm
Thanks Lem. Most I have seen on the mod motors will say like ie 113 + 4, I thought since it didn'd have that advance in it to install it per card, but thanks for clearing that up for me. I will get it to 106.
Tennessee Bullitt
Tennessee Bullitt
Post  Lem Evans February 14th 2010, 9:52 pm
Custom cams do not tell one where to install the cam....futher more the magic install on shelf cams is not perfect for all applications.
Post  Tennessee Bullitt February 15th 2010, 10:47 am
Thats why you have people like me who bug you every day and buy lots of parts from you, I love to learn all I can.
Tennessee Bullitt
Tennessee Bullitt
