Frame rail questions
+7
Treeyasoon
DanH
'65 T-BOLT
61coon
11 posters
Frame rail questions Empty Frame rail questions
Post  61coon February 14th 2010, 5:50 pm
I'm building a frame underneath my car and I'm ready to tackle the front part now.My question is this.I'm wanting to form two radius' in the rails to acheive my ride height.Most people "Z" the frame rails,but I would like to form the radius' in them.Bobby Z has a 60 Falcon in the "stuff for sale section".The way the frame rails on that car looks is exactly what I'm wanting to do.Any tips or advice?I would like to do it myself,but if I have to take it somewhere to get it done that would be okay too.Thanks for any help.---RED
61coon
61coon
Frame rail questions Empty Re: Frame rail questions
Post  DILLIGASDAVE February 15th 2010, 11:20 pm
The smooth radius curves on his Falcon's chassis are from the box tubing being bent to get the "Z" shape (vs cutting & welding to get the "Z"). Unless you have access to a tubing bender with bending dies/shoes for box tubing, your best bet is probably going to be miter cutting/welding the joints to get the Z step.
Post  '65 T-BOLT February 15th 2010, 11:30 pm
buy a set of preformed front rails! just a thought!
'65 T-BOLT
'65 T-BOLT
Post  61coon February 15th 2010, 11:37 pm
Hey Dave,Thanks for the reply.It's kinda looking like that's what I may have to do.There is a company called "On the ground performance"that forms rails the way I am wanting to do.I sent them my dimensions and they should reply back with a quote to me.If it's too high,I'll just "Z" the frame.Will I have any problems getting my car to certify to say,8.50's with the frame "Z'd"?---RED
61coon
61coon
Post  61coon February 15th 2010, 11:38 pm
I saw a set offered from S&W Race cars.I think I'll give 'em a call when they are open tomorrow.---RED
'65 T-BOLT wrote:buy a set of preformed front rails! just a thought!
61coon
61coon
Post  DILLIGASDAVE February 16th 2010, 12:35 am
61coon wrote:they should reply back with a quote to me.If it's too high,I'll just "Z" the frame.Will I have any problems getting my car to certify to say,8.50's with the frame "Z'd"?
If you don't/can't go with a one piece bent box rail, then cutting/welding the "Z" step should certify for NHRA/IHRA (or the faster SFI) specs just fine. Just remember the SFI specs are more strict on size & wall thickness of the material used for "frame rails" depending on if they fall inside the area of the main roll cage structure, and which SFI cert is used. And if you do have to "Z" the frame some small gussets at the joints might not be a bad idea just to keep the inspectors happy.
Post  DanH February 16th 2010, 4:05 am
frame rails are not part of the 8.50 cert. , last i knew just the cage around the driver was check
DanH
Post  61coon February 16th 2010, 2:07 pm
Thanks alot for the input guys,I really appreciate it!!---RED
61coon
61coon
Post  TravisRice February 16th 2010, 5:33 pm
Red, Steer away from the S&W rails, there bender crinkles the top ad sides of the rails when forming them. How they are acceptable I have no idea being they are only .083 I beleive. To each thier own, but I would save your money and buy some Alston or comparable rails.
Travis
Post  Treeyasoon February 16th 2010, 9:35 pm
I did my own front end 10 years ago and, unless you are a pro...it will be a learning experience. Mine turned out ok and it works but, I learned what NOT to do. I don't know what your budget is but, check out this set-up...it is the only way to go for a DIY kinda person, IMO. This is the kit that I wish I would have used... http://chassisengineering.com/shopDetails.asp?ProductId=1435
If you go the route I took...this is how I did mine. Chassis is certified.
Frame rail questions Racecar010
Treeyasoon
Treeyasoon
Post  richter69 February 16th 2010, 10:32 pm
DanH wrote:frame rails are not part of the 8.50 cert. , last i knew just the cage around the driver was check
yep, thats all they look at for the sticker.
Still need to do the "rest" of it right.............safety first.
I left my stock framerails and just built around them.
Post  61coon February 16th 2010, 11:02 pm
Thanks for all the input fellas.I'm probably just gonna do it myself.I'll post some pics up when I start making progress,whether is forward or reverse Laughing Thanks again---RED
61coon
61coon
Post  bbf-falcon February 17th 2010, 9:35 am
Here's mine Red
Frame rail questions IMG_1561
Post  72mav February 17th 2010, 2:14 pm
Red,
Check out Art Morrisons rails. They are pricey, but the best Ive ever seen.
You can go round tube like a strut car on the bottom rail. Bend it at the degree of caster you want,then bend a loop to weld on it to mount the upper A-arm.
Light and simple. A little reverse-engineering is involved, but not hard. Pm me if ya need some help with the bends.
Also, heres my number.989-494-9746.
Al
72mav
72mav
Post  res0rli9 February 22nd 2010, 10:32 am
Al Martin wrote:Red,
Al
Yes do the Art Morrisons rails, he will bend it to your specs... and like Al said they are nice.
Post  the Coug February 22nd 2010, 10:23 pm
Coon I am going down in the morning to see what rails I have in stock may be they will work for you and get that car going....
Post  61coon February 22nd 2010, 11:38 pm
Thanks Coug.I think 3-5 inches drop is gonna be what I'm looking for.---RED
61coon
61coon
