durabond cam bearings
+7
bbcoupe
powerstrokeace
jones
lance flake
11 posters
durabond cam bearings Empty durabond cam bearings
Post  lance flake February 26th 2010, 12:44 pm
does anybody know the part number for the wide durabond cam bearings that fit 460 engines. thanks
lance flake
durabond cam bearings Empty Re: durabond cam bearings
Post  Lem Evans February 26th 2010, 1:26 pm
FP-26-1 I got'em you want some?
Post  rmcomprandy February 26th 2010, 2:06 pm
Dura-Bond doesn't offer a set like that ... single bearings need to be bought in multiples to get there.
That is how some of us can offer them in sets of 5.
EDIT: I've actually had requests to purchase just 1 bearing to be used for the front bearing and also only 4 bearings for all positions except the rear.
You can get whatever you wish...
Last edited by rmcomprandy on February 27th 2010, 10:45 pm; edited 1 time in total
Post  lance flake February 26th 2010, 2:31 pm
thanks lem and randy. i new there was a trick to it could find a set number on their web site.
lance flake
Post  bbf-falcon February 27th 2010, 3:27 pm
The set actually consists of the #1 cam journal bearing from sets from a 351 cleveland. But, the guy's like Randy and Lem order alot of bearings , so they can get you a set of all #1 wide bearings Smile
Post  jones February 27th 2010, 6:03 pm
lance flake wrote:does anybody know the part number for the wide durabond cam bearings that fit 460 engines. thanks
Lance, those you installed for me I bought from Randy but Lem has them also.
jones
Post  lance flake March 2nd 2010, 8:38 pm
thanks fellas. i got some coming from lem.
lance flake
Post  powerstrokeace October 24th 2013, 9:19 am
so when using these do you only install the 1 bearing in front? or install all 5 bearingings?
Ace
powerstrokeace
powerstrokeace
Post  rmcomprandy October 24th 2013, 10:33 am
powerstrokeace wrote:so when using these do you only install the 1 bearing in front? or install all 5 bearingings?
Ace
The WIDER bearings are the same width as the camshaft journals where the regular bearings are about .090" narrower than the camshaft journals; (except the rear).
The bearings are #1 CLEVELAND engine bearings in a set and they fit all 5 locations of a 429/460 block.  That front bearing takes most of the abuse with the forces of the timing set also involved however, what you do is entirely up to you.
Post  powerstrokeace October 24th 2013, 12:56 pm
I would rather put them in all 5. So you buy them separate
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans October 24th 2013, 1:17 pm
What I have is a set of 5 #1 cleveland cam bearings.
Post  rmcomprandy October 24th 2013, 1:45 pm
powerstrokeace wrote:I would rather put them in all 5. So you buy them separate
Ace
You could buy 5 separate #1 Cleveland cam bearings if you wanted to pay a lot of money for the individuals.
When we buy them a hundred bearings or more at a time, they are not near as expensive and the sets of them are less money to you...
Post  powerstrokeace October 26th 2013, 11:10 am
Lem
Called today and talked to Aron and got the cam bearing coming. but he was unable to find a price on a B460 head gasket set...
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans October 26th 2013, 11:20 am
powerstrokeace wrote:Lem
Ace
$53 for the head gaskets.
Post  bbcoupe November 20th 2014, 1:53 am
Are these no.1 Cleveland bearings the ones now available as a set on the the Durabond site?
"FP-30AT Notes: HIGH PERFORMANCE; (Special Bearing Set w/ Wide No. 1-5 Position); (Coated)/OHV /8Cyl 7.0L 7030CC 429 V"
bbcoupe
https://www.youtube.com/user/coupe545
Post  rmcomprandy November 20th 2014, 1:37 pm
It is a NEW part number and Dura-Bond now offers a set of wide bearings but, only in the expensive "coated" variety.
When I sell out of my "coated" sets I will not offer the higher dollar coated bearings anymore however, the High Performance UN-COATED "wider" cam bearing set will still be available from me.
The last time I inquired to Dura-Bond about them this past summer ... they didn't have any sets on the shelf to be shipped.
Maybe they do now.
Post  bbcoupe November 20th 2014, 5:13 pm
Thanks, for the update!!
bbcoupe
Post  gt350hr November 21st 2014, 11:45 am
Randy,
At what point ( I'm thinking roller cam only) do you feel it's necessary to go to the wide bearings? Same for just doing the #1 bearing. I have a spare 351C front bearing and could change mine if "necessary" on my mild hydraulic roller combo. If not , I'm good to leave it with the standard 460 bearing.
gt350hr
Post  rmcomprandy November 21st 2014, 8:58 pm
gt350hr wrote:        Randy,
Personally, I put at least the wider front bearing in everything I build.
Valve spring pressure would decide the rest for me. Anything over 220 pounds force on the seat or 600 pounds force open I always use them whether they are really needed or not.
Post  6t6mustang December 5th 2014, 12:14 am
How much you get for an uncoated set?
6t6mustang
6t6mustang
Post  rmcomprandy December 5th 2014, 12:54 am
6t6mustang wrote:How much you get for an uncoated set?
Off the top of my head, I don't know; Go to the web site.
Post  FalconEh December 5th 2014, 2:27 am
rmcomprandy wrote:It is a NEW part number and Dura-Bond now offers a set of wide bearings but, only in the expensive "coated" variety.
Maybe they do now.
Randy,
Why are the expensive "coated" variety not the High Performance version?, or is it the coating is overrated but less affordable and the wider version is High Performance whether is is coated or not?.
Post  6t6mustang December 5th 2014, 12:24 pm
they are, they are Teflon coated race bearings, $80 set through summit..
6t6mustang
6t6mustang
Post  the Coug December 5th 2014, 1:19 pm
6t6mustang wrote:they are, they are Teflon coated race bearings, $80 set through summit..
I suggest if you don't like the dealers on here prices then you need to go to Summit and get engine build advice from them...... JMHO
Post  6t6mustang December 5th 2014, 1:40 pm
who are you? the sergeant at arms? this is a tech forum, he asked what the coated bearings were, coated standard or coated race, I answered and gave him an option with a price..
6t6mustang
6t6mustang
