Cylinder Wall Finishing
DaveMcLain
BIGDOG466
Anyone seen or used Laser Structuring in their cylinder walls? Heard "some" Pro-Stock guys are using it, and none where FORDS. Pretty neat process, I was told that "they may not see the difference down low but top end pull tells the story"
http://www.gehringlp.com/en/c2-1.php
Last edited by BIGDOG466 on February 27th 2010, 5:41 pm; edited 1 time in total (Reason for editing : spelling)
BIGDOG466- Posts : 265
Re: Cylinder Wall Finishing
I've heard of that technology but I don't know anyone personally who's using it but it sounds expensive.
DaveMcLain- Posts : 399
Be interesting to know who is using the process. Does sound interesting.
Nevs- BBF CONTRIBUTOR
I can find out, I was at Gehring for two days last week during a machine run off. It will be later next week but I will find out what condition the block needs to be when it is sent to them. I believe they will hone it to your spec's after the laser process is done. I couldn't drag any more info from them on who was using it, just that "Pro Stock boys don't what you to know". You would think for a 1.5 Million $ Honing machine they would tell me something
BIGDOG466 wrote:I can find out, I was at Gehring for two days last week during a machine run off. It will be later next week but I will find out what condition the block needs to be when it is sent to them. I believe they will hone it to your spec's after the laser process is done. I couldn't drag any more info from them on who was using it, just that "Pro Stock boys don't what you to know". You would think for a 1.5 Million $ Honing machine they would tell me something
For that kind of money you would think so. Thanks for sharing regardless. I'd never heard of it before.
I wonder how the round holes or square holes in the cylinder walls make a differance? That is if that's what they are talking about.
jones- Posts : 2230
Or maybe they won't tell you who's using the process because nobody does, you never know....
read
I will get some more info this week. I may send a block to them.
Here is some more info,
http://www.aa1car.com/library/plateau_finish.htm
Sounds interesting, wonder how much it cost. Are the holes just to hold the oil?
bb429power- Posts : 3129
bb429power wrote:Sounds interesting, wonder how much it cost. Are the holes just to hold the oil?
It says 500-750 dollers
res0rli9- BBF CONTRIBUTOR
» CYLINDER WALL THICKNESS ON NON THRUST SIDE
» Finishing touches: carb, push rod, rocker questions
» motorpsort block sleeve thickness
» Piston to wall clearance?
» Wall Hanger
» Wall Hanger
