Taking The cougar to chassis dyno
+7
longroofracer
511Fox
'65 T-BOLT
cheatham
11 posters
I'm gonna take my cougar to a chassis dyno tomorrow. Not really expecting big numbers, but wanting to get my timing dialed in and see where peak power is. Dyno jet dyno. Should be interesting I thing I may be running one of the smallest big blocks on here, 429 with procomp heads...
429 .030
small dome piston
h beams
.258/.260 @50 640/640 lift 108'
4150 Victor 850 Holley
Will let ya'll know what happens...
429 .030
small dome piston
h beams
cheatham- Posts : 267
Re: Taking The cougar to chassis dyno
cool deal let us know ..... and take some video
yeah, taking the wife so she can run the video. ya'll dont give me to much sh33t for low numbers, just a guess but i think maybe 350 rwhp
good luck Shane, you need anything give me a shout.
Well, did you make it to the dyno? how did it do?
'65 T-BOLT- Posts : 1464
I would love to see how much a 435 CID makes
I wont give anyone crap I don't own a Ford yet
Have pity on the Blue Ovalless
511Fox- Posts : 251
Well we got back from the dyno, numbers were, with my carb: 353 hp @ 6500 with there carb 363@6500 peak torque was 347@ 5000 with my carb and 351 with there carb.
My carb was getting fat up high and had 80/80 jets in it we changed jets 75 in the front 76 rear and picked up power went from 345 to 353
Will try to scan the sheets in the morning here are some videos.
https://www.youtube.com/watch?v=x5cRNjS0x2E
https://www.youtube.com/watch?v=qawgVdSAPno
https://www.youtube.com/watch?v=M2fV8ODIKfA
ok how much is that in fly wheel hp???
res0rli9- BBF CONTRIBUTOR
Looks like it was right where you expected it to be... no disappointments there.
longroofracer- Posts : 250
good job! right where you thought it would be!
I wonder what a 429 would make with p-51's? or your 435
I'd say that's very respectable for your combination. Good deal!
Nevs- BBF CONTRIBUTOR
Maddmattmustangs wrote:I wonder what a 429 would make with p-51's? or your 435
I have seen those rwhp numbers with a c6 and ported iron heads with large valves at 5,500 rpm with a 20 degrees less cam duration.
The p-51's would do the same thing with a bunch less cam and a much lower rpm.
This is an example of throwing a bunch of cam at a mediocre pair of heads getting decent numbers but at very high rpm.
Not trying to be a jerk in any way here.
I'm running a C6 and 4.56 gears, while I'm ok with these numbers I have went backwards. My 460 with flat tops way down in the hole, stealth intake, cam, .244/254 .588/614 112*, c9ve heads only the bump in exhaust ground out, big valves and turbo mufflers made, 320 hp @ 6000 & 398 ft torque.
But hey I'm all about learning and trying things out, this aint a bad little motor, its is lighter, and It doesnt heat up as bad. My car weighs 3650 lbs and has done an 11.90 @ 113 with a 1.8 60ft. I think there is more in it ! PLUS I got a set of the new SCJ's just waiting to be used.
Oh here's something else It made peak power with 36* timing.
Hind site probably would have got diff. heads but I'm having fun
cheatham wrote:I'm running a C6 and 4.56 gears, while I'm ok with these numbers I have went backwards. My 460 with flat tops way down in the hole, stealth intake, cam, .244/254 .588/614 112*, c9ve heads only the bump in exhaust ground out, big valves and turbo mufflers made, 320 hp @ 6000 & 398 ft torque.
something to be said for cubic inches.....and cyl heads.
race the car and have some fun, in the meantime gather parts for your stroker build....................get a cage, traction device etc.
res0rli9 wrote:ok how much is that in fly wheel hp???
Assuming a 20% loss through the drivetrain you end up with 441hp and 434 ft-lbs of torque at the flywheel.
dablack- Posts : 18
» chassis dyno???
» Engine VS Chassis Dyno
» suggested items needed for chassis dyno tune
» Mild (less than ideal) 466 chassis dyno results, guesses for conversion to flywheel horspower
» chassis Dyno Results and problems
