AOD behind a big block
70bbftorino
Maddmattmustangs
Page 2 of 2 Previous  1, 2
AOD behind a big block - Page 2 Empty Re: AOD behind a big block
Post  Maddmattmustangs April 13th 2010, 7:27 pm
hollenjoe wrote:Ok ive been doing some reading, The integral bellhousing AOD requires a flexplate with 164 teeth (approximately 14 1/4" diameter with an 11 7/16" torque converter bolt pattern) for proper starter placement and converter compatibility. The original 351m/400 used a similar flexplate with 10.5" torque converter Bolt Pattern and 28 oz-in crankshaft imbalance. So I found this 351m/400 TCI flexplate with 164 teet, 11 7/16" torque converter bolt pattern, and 28 oz-in crankshaft imbalance :
http://www.performancetransparts.com/fordsfi291approvedflexplate28ozbalance164tooth.aspx
It seams to match the aod, or is there another reason why it wouldnt?
I think this is the flexplate im looking at running behind my 393C i was going to just drill new wholes in it for my converter if it doesnt fit and have it rebalanced.
Maddmattmustangs
Maddmattmustangs
Post  hollenjoe April 13th 2010, 10:34 pm
If just drilling holes and rebalancing it is possible, I think its a way to go... Im gonna ask around and trying to get opinions on this
hollenjoe
Post  Maddmattmustangs April 13th 2010, 11:15 pm
hollenjoe wrote:If just drilling holes and rebalancing it is possible, I think its a way to go... Im gonna ask around and trying to get opinions on this
I know one way to get around the whole darn problem is to internally balance the engine and just use a neutral balance flywheel and dampener. As long as all wholes are made equally it wouldnt be a problem.
Maddmattmustangs
Maddmattmustangs
