Fiberglass body
KY JELLY
665 falcon
Fiberglass body
Does anybody no if they make a 71/73 ford mustang fastback fiberglass body. Only thing i can find is the pro front end, doors, and trunk lid. Thanks
665 falcon- BBF CONTRIBUTOR
Re: Fiberglass body
Build you a mold Bobby you can do it Just build the car out of carbon fiber instead
http://www.hotrodder.com/32Blowpar/page11.html
KY JELLY- Posts : 1530
Re: Fiberglass body
Thank's Randy, i have been reading up on that very thing
Re: Fiberglass body
KY JELLY wrote:Build you a mold Bobby you can do it Just build the car out of carbon fiber instead
Yea, I like that site. It's been a great site for getting 'glass/plug/mold ideas.
Only problem with using carbon fiber vs 'glass is the carbon really needs to be vacuum bagged for best results. And that can be a real chore on complicated mold shapes like the main body shell, or a one piece nose. Smaller "flat" stuff like the hood, trunk lid, & outer door skins are much easier to vacuum.
DILLIGASDAVE- Posts : 2262
Re: Fiberglass body
I guess the main reason for the vacuum bagging is to get the lightest part possible by getting rid of he excess resin ? I am sure it confirms to the mold better , but something complex as a car body would be hard to do.
Re: Fiberglass body
Yes it is. Even Mr. Bohica would approve.DILLIGASDAVE wrote:KY JELLY wrote:Build you a mold Bobby you can do it Just build the car out of carbon fiber instead
longroofracer- Posts : 250
Re: Fiberglass body
longroofracer wrote:Yes it is. Even Mr. Bohica would approve.
Mr. Bohica is a wealth of 'glass knowledge in my book.
Re: Fiberglass body
KY JELLY wrote:I guess the main reason for the vacuum bagging is to get the lightest part possible by getting rid of he excess resin ?
Yes, vacuum bagging helps remove excess resin for lighter parts. And bagging also helps remove more trapped/hidden air bubbles that you might miss by hand with a brush or roller.
Re: Fiberglass body
DILLIGASDAVE wrote:KY JELLY wrote:I guess the main reason for the vacuum bagging is to get the lightest part possible by getting rid of he excess resin ?
I hate to be an A$$ here, but who is Mr Bohica. Im sorry i do not no
Re: Fiberglass body
Fiberglass/composites guru from the old Net54 site. Had a ton of knowledge in other areas too.665 falcon wrote:who is Mr Bohica.
Re: Fiberglass body
From what I understand the vacuum part helps spread the minumum amount of resin through the carbonfiber. Supposedly if you put to much resin the part will be too brittle. Then your suppose to bake the part while under vacuum. I watched a show on how they produced the parts for $$ racing. It seemd amazing how little resin they used, then when they put it under vacuum it just did spread through out the part!
I guess this is if you are using it for structural design and need it as lite as posable.
jones- Posts : 2230
Re: Fiberglass body
If I remember correctly not all carbon fiber needs to be cooked in an oven. One deciding factor is the type of resin used. Pre-preg carbon fiber (carbon fiber cloth that comes pre-coated with resin) is one type that has to be cooked in an oven. The heat makes all the coated rubber(ish) like carbon/resin layers flow together & it also catalyzes/activates the resin coating so it will harden. I don't think you have to "cook" something like the lower priced "carbon" wheel tubs & interior pannels (that are really a mix of both carbon fiber & fiberglass layers to help keep the cost down) because I think they use a resin (that you add a catalist to) that is compatible with both materials.jones wrote:Then your suppose to bake the part while under vacuum.
Re: Fiberglass body
Thank's for the reply guys, i find this very interesting.
Re: Fiberglass body
Here is a video of vacuum infusion Mr Z
Re: Fiberglass body
665 falcon wrote:Does anybody no if they make a 71/73 ford mustang fastback fiberglass body. Only thing i can find is the pro front end, doors, and trunk lid. Thanks
I hear ya they need a coupe body as well
» 50's tbird fiberglass body
» fiberglass body parts
» Fiberglass
» Any intrest in a fiberglass 66 Mustang Fastback body
» Carbon Graphite Doors for 64 fairlanes
» Fiberglass
