does anyone make a 4.30 pro gear for 8.8
need a stronger gear shot that baby off the line with motive gears and eat ring gear up.it lock up and messed the tranny up. so i have not seen any pro gears for 8.8 but have seen guys fly with them. i got all good stuff as far as axles 35 spline and spool with long studs i put the 9in ends on a 8.8 with a girdle.been running the car for about year no problems when i shot it off the line 150 shot sounded like the car was taking a dump any help will be very thankful.
bigjohn2007- BBF CONTRIBUTOR
Re: does anyone make a 4.30 pro gear for 8.8
I have never broken 8.8 gears. I also never use pro gears but have never ran that steep of gears either. We run 3.70 gears on our sb turbo car and when we had the nitrous engine in running mid 5's we were running 3.73's from Ford motorsports. I hear that Motive is making these now but I'm not for sure.
You're running taller tires so I understand your need. If I was you I would probably go back with those but strange and MW both make strong gears but I'm not sure about the softer "pro" versions. Richmond has a "pro" 4.11 now.
whatbumper- Posts : 3024
thanks just got a set richmond pro gears they were 774.95 + shipping from summit they had them drop ship from richmond cause they did not have them on the shelf yetwhatbumper wrote:I have never broken 8.8 gears. I also never use pro gears but have never ran that steep of gears either. We run 3.70 gears on our sb turbo car and when we had the nitrous engine in running mid 5's we were running 3.73's from Ford motorsports. I hear that Motive is making these now but I'm not for sure.
$775 plus shipping. OUCH!!
run three passes and took out need higher gear with powerglide so if someone needs them their for sale.whatbumper wrote:$775 plus shipping. OUCH!!
i have the motorsport 3.73 gear set in my 8.8 ..... not mid 5's yet but they have taken some abuse ......
yes they will take alot of abuse just like the 8.8bruno wrote:i have the motorsport 3.73 gear set in my 8.8 ..... not mid 5's yet but they have taken some abuse ......
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
» 460 rotor gear connecting gear bad
