Steering shaft ?'s
Steering shaft ?'s
Anybody have a slight fitment problem with running the D&D 2 1/8 headders around a fox steering shaft? It's looks like the headder tube might need slight tweaking so the shaft can turn without interference.
Re: Steering shaft ?'s
Check into the flaming river shaft kit.
Is modifying the shaft's (both or either) length an option to change the angle of approach?
Dave.
Dave.
LivermoreDave- Posts : 972
I tried all that, I even took out the bushings and set it up to look like it was offset, nothing works. I got a lot of good info from AJE to check out all possiblities. I know D&D said the newer mustangs said the problem would be the drive shaft [99-04] I just wanted to see about the foxes. I am going to tweak the tubes a little so it can turn. Nothing that is going to affect the flow in any way.
» STEERING SHAFT
» Fox steering shaft
» SCJ and ported C8 472'' in the works (both finally done)
» wtb fox manual rack and steering shaft
» What does the NHRA rulebook say about the steering shaft/system??
