STEERING SHAFT
STEERING SHAFT
What's the differant between the manual steering shaft and the power steering shaft?
tconnection- Posts : 866
Re: STEERING SHAFT
On a factory fox mustang, the shafts are the same. The difference is in the coupler at the end. Manual's will have a smaller splined hole for the manual steering rack than a power assisted coupler. There used to be someone selling a an insert on E-bay, that would fit inside a power steering coupler to adapt down to a manual rack. It is splined on the ID and OD.
Jess
Jess
Mustang-junky- Posts : 438
Re: STEERING SHAFT
I got my shaft in today. Thanks for the info.
Re: STEERING SHAFT
Where can I buy the steering shaft coupler that adapts from power to manual?
Re: STEERING SHAFT
Summit , jegs , speedway , junkyard ...... take your pick
gmsmkr- Posts : 1364
Re: STEERING SHAFT
I know j can get another spline u joint. I'm after the coupler that has splines on the inside and outside that will fit up in my existing spline u joint.
Re: STEERING SHAFT
I bought mine on E-bay. I could get you a picture if you want, but it has been several years since I bought it. Can't remember the sellers name.
Jess
Jess
» Fox steering shaft
» cant get steering
» Steering shaft ?'s
» 55 staight axle swap 02 ranger ifs donor truck
» What does the NHRA rulebook say about the steering shaft/system??
» cant get steering
