cant get steering
cant get steering Empty cant get steering
Post  mikey hefner December 11th 2012, 11:17 am
hi everyone, i hope im posting in the right section. if not please forgive me!! i have an 86 coupe that ive installed a mild 466 with hooker swap headers, 1.5 inch k member spacers, solid side mounts, upr k member kit and flaming river manual rack. the issue im having is getting the manual rack steering shaft threw the headers. ive tried lowering the column, prying the colapsable part of the steering column out, pushing it in and i just cant come up with the right combination of up down in out to get the shft installed. its made up of dd shaft with the large u joints. any help, pics of installs, anything will be greatly appreciated!!!
mikey hefner
cant get steering Empty Re: cant get steering
Post  IDT-572 December 29th 2012, 12:11 pm
Over the years, I have had to move the engine around, cut header tubes, ect. just what ever needed to be done.
Post  dfree383 December 29th 2012, 12:57 pm
Flaming river make a small one too.
Post  GTmustang December 30th 2012, 7:48 am
dfree383 wrote:Flaming river make a small one too.
The Flaming River kit with the smaller diameter u-joints works.
Gary
GTmustang
Post  mikey hefner January 2nd 2013, 12:34 pm
thanks guys, im hoping to get this thing all figured out. first time building a car like this. just glad to have a site like this to get help and advice. much appreciated!!!! any part numbers on the small diameter u-joint kit??
mikey hefner
Post  GTmustang January 2nd 2013, 3:23 pm
I used the Flaming River FR1504MLP shaft kit wich is a low profile chromemoly kit for manual steering 79-93. The universals are only 2/3 the diameter of their regular kits.
www.flamingriver.com/index.php/products/c0008/s0006
Gary
GTmustang
Post  mikey hefner January 5th 2013, 7:25 pm
Thanks Gary, I'll give that shaft set up a shot!
mikey hefner
Post  501ranger January 5th 2013, 9:38 pm
I think the Hooker headers have two tubes that can be removed. Can you remove part of the header, install the steering shaft, then reinstall the header? You might also need to modify the header tube for clearance.
501ranger
501ranger
Post  mikey hefner January 6th 2013, 8:49 pm
I've got the header bolted in, all tubes. Since I spaced the column down, it almost fits. I just need to get a smaller u joint and I think it'll work I hope. I've been tossing the idea of a custom header around and stop all the fighting with the steering shaft. Last attempt will be with the smaller joint that's all I can do to try and get it to work. Unfortunately I can't do any fab work, I can bolt stuff together just don't have the other needed skills or equipment to do fab work. I thank you all for taking the time to help!! It means a lot.
mikey hefner
