Fox steering shaft
Fox steering shaft Empty Fox steering shaft
Post  Coupe Devil June 15th 2015, 9:04 am
Whats available to upgrade the steering shaft in these cars if staying with power steering? I have seen people replace them with joints at the steering column and rack but not sure where they are getting the joints and shaft parts.
Coupe Devil
Coupe Devil
https://www.facebook.com/NCSpeedlab
Fox steering shaft Empty Re: Fox steering shaft
Post  whitefield June 15th 2015, 9:11 am
Jegs , summit , Cj, pony parts. UPR, ect..., will have what you need .        Forgot Flaming river too !
whitefield
whitefield
Fox steering shaft Empty Shaft
Post  MustangBBF June 22nd 2015, 3:21 pm
Maximum Motorsports has great options for PS.
What I use in my car.... Link below
http://www.maximummotorsports.com/MM-Steering-Shafts-C14.aspx
-Joe
MustangBBF
Post  bonfire July 16th 2015, 10:40 pm
I used same piece. Collapse able is nice feature. It is bare so be prepared to paint or powder coat. I chose the latter
bonfire
Post  MustangBBF July 17th 2015, 8:02 am
You powder coated the slip piece? My friend tried painting his and it would not slip anymore. ended up wire wheeling the paint off so we could move it when needed. Just have to keep it oiled for rust.
MustangBBF
Post  bonfire July 17th 2015, 9:23 am
sure did.....the guy baked it at a lower temp so as not to melt the sleeve that covers the joint. No issue with the functionality afterwards. This was a restoration as well as a hotrod effort project so thee was no way I'm putting something that is going to rust on it. I had many part powdered including the rear axle
bonfire
