CAMS ? STREETABILITY
+10
511Fox
LivermoreDave
DaveMcLain
blown473
badnotch
14 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: CAMS ? STREETABILITY
Gerry,
I think Travis hit the nail on the head for cam lift,duration and spring pressure.My cam is .670-.690 lift with 256-266 duration at .050 and the springs i'm currently using have 225 lbs.seat pressure at 1.95" installed height and 555 lbs. open pressure at 1.25".The only thing with the size engine you're building will be the compression with that size cam since it might seem small in a 600" engine and build alot of cylinder pressure.Are you planning on running pump gas or race gas,if pump gas you will have to find some really big dish pistons with the C-Heads IMO.I don't know nearly as much as some people on here so i don't know how accurate i am.Gerry i drive my car on the street alot is it streetable in my opinion yes does it have a smooth idle no but i have no problems driving it on the street.
Later Mark.
Later Mark.
Mark Miller- Posts : 1958
To me "streetable" means that it must idle like a Crown Vic with the AC on, and pull strongly to 9500 rpm.
cletus66- Posts : 865
rmcomprandy wrote:Maddmattmustangs wrote:I plan on swaping out my springs every 12 months wether they need it or not. rather pay 350 for springs than 10,000 for a new motor imo.
Honestly, it seems everyone has a different idea of whats Streetable and whats not. i know guys that say .500 lift and 216* @ .050 is not streetable at all. i know others with cams in the .750 range that call there cams a medium sized performance street cam.
It comes down to how often can you and or are willing to service your valvetrain, the size of your pocket book, and how you drive.
just my .02
You're not understanding the point ... the extra pressure creates other problems with streetable endurance besides simply the springs themselves.
Lifters, pushrods, rockers, valve seats, valve stems, guides, retainers, locks. valve seats, pushrods, lifters, rockers and the valve stem tips taking the brunt of the abuse.
so how does this sound for a street cam.
254/260 duration @ .050
292/298 duration seat to seat
.671/.678 int/ex lift.
110 lobe seperation angle.
gonna try and get compression around 10.5 -11.1 gonna have to order an inverted dome
badnotch wrote:gonna try and get compression around 10.5 -11.1 gonna have to order an inverted dome
did you check out Theo's 608...9.4 compression on pump gas...942hp
res0rli9- BBF CONTRIBUTOR
badnotch wrote:yes ive pmed him and hes not got back to me yet thanks
he hasnt be on here in a long time but ive got his email if you would like to try that just pm me.
What Is Wrong With N/A
blown473 wrote:Its simple, smaller cam, BIGGER POWER ADDER!!!!
What is wrong with N/A
There is replacement for HUGE Displacement
511Fox- Posts : 251
511Fox wrote:blown473 wrote:Its simple, smaller cam, BIGGER POWER ADDER!!!!
there is nothing wrong with N/A
Page 2 of 2 • 1, 2
» Streetability and other definitions
» Comp cams thumpr cams.....
» Streetability: Horsepower & Torque
» COMP Cams 34-229-4 - COMP Cams Magnum Hydraulic Cam/Lifters
» Dove heads on stock 460
Page 2 of 2
