Dealer or supplier for scratch proof lexan ??
Anyone here a dealer or have a good supplier ?? Are there different companies with different grades of scratch proof lexan ??
Travis
Travis
TravisRice- BBF CONTRIBUTOR
Re: Dealer or supplier for scratch proof lexan ??
http://www.usplastic.com/catalog/item.aspx?itemid=23753&catid=704
is that what you are looking for Travis ?
Travis,When I did the glass in the Maverick, I went to the local glass shop and he had a book w/all the different grades of lexan in it.
I just go to a local plastics supplier down the road in Fort Worth for clear 1/8" GE Lexan & Margard sheets. I would check locally, no reason to pay for shipping if you can get the stuff around your town.
DILLIGASDAVE- Posts : 2262
Travis! we have Milmar plastics in Lietersburg (Hagerstown area)
'65 T-BOLT- Posts : 1464
Found a local supplier that the construction company I work for subs work to all the time. He has it in stock. Next question is do any of you guy's run the tinted stuff or generally just stick with the clear ?? Was wondering if the tinted showed light scratches worse than the clear ?? Any thoughts or input ??
Travis
Travis
I ran the tinted Travis, I liked it real well. The good stuff like Nascar uses won't scratch unless you try too intentionally.
Just be sure it is the mar resistant.
Nevs- BBF CONTRIBUTOR
DILLIGASDAVE wrote:I just go to a local plastics supplier down the road in Fort Worth for clear 1/8" GE Lexan & Margard sheets. I would check locally, no reason to pay for shipping if you can get the stuff around your town.
saME HERE..................
motherf-in capslock
» Supplier for 60 MM Roller Cam Bearings
» Complete A scratch 428 in Ga. SOLD
» I finally got my 528cu engine scratch that, still being buit with changes! LoL
» Scratch on Cylinder Head Combustion Surface
» Is the CaPe hEaT PRooF?
