Help Piston to valve clearance
Help Piston to valve clearance Empty Help Piston to valve clearance
Post  westsideford August 17th 2009, 10:39 pm
Running a solid flat tappit cam.
I'm at .015 with the lash set to zero. Can I get by with .030 lash?
I had the cam advanced and it made it worse I believe The above is at 0* or straight up.
Intake has a mile of clearance..
I seem to remember something like .100 clearance but don't remember which valve that was?
Thanks to all that reply.. I'm in a crunch 23 days to Pinks All Out..
westsideford
westsideford
Help Piston to valve clearance Empty Re: Help Piston to valve clearance
Post  DanH August 17th 2009, 11:59 pm
westsideford wrote:Running a solid flat tappit cam.
if you need exhuast valve CL , advancing the cam --should have got more ex/v clearance. best check your cam degreeing again . edit, is this a wide angle --LSA cam
DanH
Post  dfree383 August 18th 2009, 6:28 am
IMO way to tight you want at least .060-.080, try moving the cam around like Dan is suggesting.
