VALVE-PISTON CLEARENCE
PAPPY
VALVE-PISTON CLEARENCE Empty VALVE-PISTON CLEARENCE
Post  PAPPY January 28th 2018, 2:36 pm
Have been trying to put a build together and am curious if a flat top piston motor with stock stroke and PI heads would need help if I use a cam with 0.664 & 0.671 lift. wonder if I need different pistons
PAPPY
VALVE-PISTON CLEARENCE Empty Re: VALVE-PISTON CLEARENCE
Post  jbozzelle January 28th 2018, 3:13 pm
depends on the pistons you use and if they have deep enough reliefs already. Only way to tell would be to mock up one cylinder and check
Post  dfree383 January 28th 2018, 3:44 pm
What he said, got to mock up and check
Post  PAPPY January 28th 2018, 5:29 pm
Was afraid that would be the case. Guess I just hoped someone had already been there. I thank you for your honest response. Think I'm goining ahead with it and take my chances. Again thank you.
PAPPY
Post  gt350hr January 29th 2018, 2:04 pm
Flat tappet or roller? Duration @.050 and lobe separation?
gt350hr
Post  airford1 January 29th 2018, 2:56 pm
Bet this will be his last post. Cant imagine not checking the clearance.
airford1
airford1
Post  dfree383 January 29th 2018, 3:21 pm
PAPPY wrote:Was afraid that would be the case. Guess I just hoped someone had already been there. I thank you for your honest response. Think I'm goining ahead with it and take my chances. Again thank you.
It literally takes 15 minutes to check with some molding clay, it's not an involved process.
Better to check ahead of time rather than waste good parts
Post  jasonf January 29th 2018, 4:49 pm
It's not a cheap fix if you are wrong.....
Post  airford1 January 29th 2018, 5:19 pm
Pappy you are going to SMACK the PISTONS. I feel we need intervention in this case. Who's close to Pappy to step in and give him the support to not destroy a ford motor.
airford1
airford1
