Ok my new engine won't crank ?!!!
Barney
Big block fox 339
Ok my new engine won't crank ?!!! Empty Ok my new engine won't crank ?!!!
Post  Big block fox 339 March 26th 2010, 8:40 am
Ok I tried starting my 545 last night this my first build I'm a Lil worried. I put the dist in at 16 degrees before tdc. It spun a few seconds then it got fuel but still didn't fire off the weird thing is when you spin It then turn the key off it sounds like It starts spinning really fast and starts blowing air out of the carb what did I do wrong ? Sorry I'm a newb
Big block fox 339
Big block fox 339
Ok my new engine won't crank ?!!! Empty Re: Ok my new engine won't crank ?!!!
Post  jasonf March 26th 2010, 8:55 am
Did you put the distributor in 180 out. It is a very common mistake.
Post  Big block fox 339 March 26th 2010, 9:09 am
I don't think I did I stuck my finger in the spark plug hole I was own compression stroke I think
Big block fox 339
Big block fox 339
Post  bbf-falcon March 26th 2010, 1:34 pm
Sounds like it's out a little. When the marker is about 10* ,look and see if it's pointing at the #1 plug wire terminal on the cap. And are you sure that the valves aren't too tight Exclamation
Post  Big block fox 339 March 26th 2010, 1:59 pm
I'm going back to the shop tomorrow to play with the timing and make sure it's fireing my engine builder did my valves I'm not sure
Big block fox 339
Big block fox 339
Post  Barney March 26th 2010, 2:38 pm
Is your box wired to cut power while cranking?(happens alot) Are you getting spark while cranking?(have you checked).
Barney
Barney
Post  Northwest outlaw March 26th 2010, 2:41 pm
180* will still blow your finger off the hole you have to look at the blancer to double check. Check for spark
Northwest outlaw
Northwest outlaw
Post  Big block fox 339 March 26th 2010, 2:45 pm
I'm gonna check the spark first thing tomorrow it's almost like it ain't fireing till you turn the key to run I'm gonna check spark while cranking if I can figure a way to do it by myself lol
Big block fox 339
Big block fox 339
Post  138 March 26th 2010, 2:56 pm
Northwest outlaw wrote:180* will still blow your finger off the hole you have to look at the blancer to double check. Check for spark
take the valve cover off to make sure its on the right stroke.... both closed at tdc
138
Post  Big block fox 339 March 26th 2010, 3:06 pm
I'm 99.99 % sure there both closed but this is my first time
Big block fox 339
Big block fox 339
Post  Barney March 26th 2010, 4:10 pm
What ignition are you running? alot of times people run switched power from a source that is killed during cranking so they get no spark while cranking.
Barney
Barney
Post  Big block fox 339 March 26th 2010, 4:28 pm
It's a msd 6al the digram on the back says the to big wires go to the battery and one small goes to switched 12volt is that key crank or run position I have it on run
Big block fox 339
Big block fox 339
Post  Barney March 26th 2010, 5:24 pm
The small red must go to a switched 12v source that remains on when cranking. Use a testlight to find and a remote push button to find a source that stays lit while the engine is being cranked. If you cnverted from duraspark I believe the red wire in the IGN harness that went to the + on the coil originally has 12v switched. I have Painless switches and wiring and its been awhile since i tapped into a stock harness. Sorry I couldnt be more specific.
Barney
Barney
Post  Big block fox 339 March 26th 2010, 6:10 pm
Barney wrote:The small red must go to a switched 12v source that remains on when cranking. Use a testlight to find and a remote push button to find a source that stays lit while the engine is being cranked. If you cnverted from duraspark I believe the red wire in the IGN harness that went to the + on the coil originally has 12v switched. I have Painless switches and wiring and its been awhile since i tapped into a stock harness. Sorry I couldnt be more specific.
Thank you I didn't think about that il check it tomorrow
Big block fox 339
Big block fox 339
Post  jones March 27th 2010, 1:35 am
Give me a call Saturday, I'll come over and help you out if you want. We will get it going!!
jones
Post  Big block fox 339 March 27th 2010, 8:39 am
Thanks bud I sure appreciate that
Big block fox 339
Big block fox 339
Post  Big block fox 339 March 27th 2010, 1:44 pm
Thanks for all the help guys i had the ignition wire ran to a wire that cut when the key was in crank position fired right off ran perfect!!
Big block fox 339
Big block fox 339
Post  res0rli9 March 27th 2010, 2:45 pm
cheers cheers
Post  bbf-falcon March 27th 2010, 3:02 pm
Barney wrote:Is your box wired to cut power while cranking?(happens alot) Are you getting spark while cranking?(have you checked).
If the box doesn't fire while cranking, when does it fire. After you stop cranking Question lol!
