Oil pressure
+9
hienergy557
devildog
342g
13 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Oil pressure
jesse wrote:that build was a
svo block
4.300 stroke
6.8 rod
4.440 bore (530 cid limit in my class)
melling hv pump
rear sump moroso
tfs A heads
nice setup but I ment harolds engine...
138- Posts : 1593
Re: Oil pressure
342g wrote:BIGDOG466 wrote:Hell, I tought you where running it!!! I would run it.
No we had it on a motor stand, using a air drill, about 800 rpm's, the needle looked like a humming bird fluttering, I have to run my fuel line, and put my new fuel pump on it, we will prolly put the motor in Monday, be ready to test Friday night if everything is good to go.
I went back and seen you posted that didn't see that. I would still run it, I'm surprized it would turn it fast enough to get 80 must have a bad azz drill what RPM does it run at 5000? If so poor pump thinks the engine is winding 10000
BIGDOG466- Posts : 265
Re: Oil pressure
Yeah, we are going to run it, but I will keep a close eye on it. every thing else seems spot on, so it must be just the air drill, we shall see next week.
342g- BBF CONTRIBUTOR
Page 2 of 2 • 1, 2
Page 2 of 2
